I have following code, which should convert hpa to mmhg pressure from 2 sensors and calculate mid value but when is 1 of sensor is unavailable it should return unknown value, not zero so as not to break the graphics.
Everything worked well until recently updates.
btw In developer Tab it works as should.
- trigger:
- platform: time_pattern
minutes: '/5'
- name: home_atm_pressure_mmhg
state: >
{% set tualet = states('sensor.tualet_climate_pressure')|float(0) %}
{% set kuhnya = states('sensor.kuhnya_climate_pressure')|float(0) %}
{% if ((tualet + kuhnya)*0.7500637)/2|round(0) > 400 %}
{{ (((tualet + kuhnya)*0.7500637)/2)|round(0) }}
{% else %}
Unknown
{% endif %}
icon: mdi:gauge
unit_of_measurement: 'mmHg'
here is Error
Error adding entity sensor.home_atm_pressure_mmhg for domain sensor with platform template
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 658, in state
numerical_value = int(value)
ValueError: invalid literal for int() with base 10: 'Unknown'
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 661, in state
numerical_value = float(value)
ValueError: could not convert string to float: 'Unknown'
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 580, in _async_add_entities
await coro
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 892, in _async_add_entity
await entity.add_to_platform_finish()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1359, in add_to_platform_finish
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1009, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1132, in _async_write_ha_state
state, attr, capabilities, shadowed_attr = self.__async_calculate_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1067, in __async_calculate_state
state = self._stringify_state(available)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1015, in _stringify_state
if (state := self.state) is None:
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 665, in state
raise ValueError(
ValueError: Sensor sensor.home_atm_pressure_mmhg has device class 'None', state class 'None' unit 'mmHg' and suggested precision 'None' thus indicating it has a numeric value; however, it has the non-numeric value: 'Unknown' (<class 'str'>)
