Hi, I have a sensor setup which scrapes a certain website for the current gasprice in my town.
- platform: scrape
resource: https://www.shellexpress.nl/nl_nl/station/se-nieuwerkerk-aan-den-ijssel
select: ".price-actual"
value_template: '{{ value.split(" ")[0] }}'
unit_of_measurement: "EUR/L"
It looks ok on the frontend but the value doesn’t seem to be an integer (probably because of the comma (?)). When I use my value in TTS, it speaks out as “one thousand five hundred and fifty nine”.
Whenever I try to convert this to an INT, it outputs value 0:
states.sensor.shell_express.state
outputs
1,559
However,
states.sensor.shell_express.state | int
outputs
0
For some reason the convertion seems to fail.
Convert the value into an integer. If the conversion doesn’t work it will return 0.
Any suggestions on how I can convert the value?
