49 Proximity sensors.
34 Zones.
Are you sure you are not automating a small country?
I didn’t bother with sensors, I just put mine straight into a markdown card (someone is going to tell me why that is a bad idea…)
34 Zones.
no, just a large family
did a small rewrite of the OP sensor with attribute_sensors and will test this shortly:
entities_domains_counter:
entity_id: sensor.date #<--- not sure if this needs to stay coming 115? maybe to keep it from updating too frequently;-)
friendly_name: Entities per domain
value_template: >
{{states|count}}
attribute_templates:
headline: >
{{states|count}} entities in {{states|groupby('domain')|count}} domains
alert: >
{{states.alert|count}}
automation: >
{{states.automation|count}}
binary_sensor: >
{{states.binary_sensor|count}}
camera: >
{{states.camera|count}}
climate: >
{{states.climate|count}}
counter: >
{{states.counter|count}}
cover: >
{{states.cover|count}}
device_tracker: >
{{states.device_tracker|count}}
geo_location: >
{{states.geo_location|count}}
group: >
{{states.group|count}}
input_boolean: >
{{states.input_boolean|count}}
input_datetime: >
{{states.input_datetime|count}}
input_number: >
{{states.input_number|count}}
input_select: >
{{states.input_select|count}}
input_text: >
{{states.input_text|count}}
light_only: >
{{expand('group.all_lights_only')|count}}
media_player: >
{{states.media_player|count}}
person: >
{{states.person|count}}
proximity: >
{{states.proximity|count}}
remote: >
{{states.remote|count}}
scene: >
{{states.scene|count}}
script: >
{{states.script|count}}
sensor: >
{{states.sensor|count}}
sun: >
{{states.sun|count}}
switch: >
{{states.switch|count}}
timer: >
{{states.timer|count}}
variable: >
{{states.variable|count}}
weather: >
{{states.weather|count}}
zone: >
{{states.zone|count}}
zwave: >
{{states.zwave|count}}
btw, Maybe I am overly puristic, but I don’t like the fake icon_templates, so took the out and customize it
sensor.entities_domains_counter:
icon: mdi:home-assistant
I know it’s 1 line extra, but the dev’s wont complain if anything goes awol…
bw, missed an important 1: persistent_notifications. But I already had that in my notification package, so added the attibute as
persistent_notification: >
{{states('sensor.count_persistent_notifications')}}
You lost 30 sensors. Did one of your zones attempt to proclaim its independence and many sensors were destroyed in the ensuing battle?
even worse!
Ive lost several Waze sensors, and Weatherbit integration:
at startup
after a while
the culprits:
hi!
not sure why you’d post that, but if your ‘pulling the data’ from this Roldy's Home Assistant - 190+ sensors - 440+ entities - 70+ automations - Floorplan you now should have noticed that could be done much better…
consider that code:
count_automations:
value_template: >
{%- set domains = ['automation'] -%}
{%- for domain in domains -%}
{%- for item in states[domain] -%}
{% if loop.first %}
{{loop.length}}
{%- endfor -%}
{%- endfor -%}
and compare it to
Hey @uiguy come here and blow their minds…
Template editor tool:
{%- for d in states | groupby('domain') %}
{{ d[0] }} - {{ states[d[0]] | count }}
{%- endfor %}
my code on @Mariusthvdb link above came initially from @Mariusthvdb i seem to remember… oh and sorry I did not credit you before…
So, I threw this into the Template editor and it popped up a long list of domains as it should, but one in particular caught my eye -
sensor - 666
Thanks 2020!
What would be the best way to display this in Lovelace? I tried a Markdown Card but the formatting was ugly, not having each domain on a new line. Is there a way for format the use of new lines in the Markdown Card?
I tried to put it in a table but failed. This is the best I can do.
type: markdown
content: |-
{% for d in states|groupby('domain') %}
**{{ d[0]|replace('_', ' ')|title }}** {{ states[d[0]]|count }}
{%- endfor %}
title: Domain Counts
Much better than mine. Thanks
Crap:
Better:
how can one make the numbers to have at least 3 digits, ie 001 instead of 1
this way to have it nicely aligned
type: markdown
content: |-
{{ '{:03}'.format(states[d[0]]|count) }} **{{ d[0]|replace('_', ' ')|title }}**
{%- endfor %}
thank you works great now, multi column would be nice instead one big list.
Now Marius, where is the “Mark this post as : - Evil Bastard” on the response options ?
I did this:
- type: markdown
# title: Components
content: >
Domain | Count
{% for d in states | groupby('domain') %}
{{ d[0].replace('_', ' ') | title }} | {{ states[d[0]] | count }}
{% endfor %}
since we were counting before…
has anyone else noticed the state machine being flooded with so many new entities (probably because of the new design decisions to breakout attributes and use dedicated sensors?
Ive been weeding out my hand made template sensors, but can not fight this… ok, I wrote a few more scripts and automations, and added a few zones but the Hue integration alone adds about 200 scenes…
Hope this wont grow out of hand…or put differently, force some serious hardware step-ups
