Roldy's Home Assistant - 190+ sensors - 440+ entities - 70+ automations - Floorplan
I would like to share my home assistant configuration example for the rest of the community to check out and hopefully get some ideas!
(If you would like an example specifically, let me know)
not that it is a competition, :grinning: It would be quite interesting to see how many of these things everyone has…
From where are you pulling the data?
  sensors:
 #----- Count Automations
   count_automations:
     entity_id: sensor.date
     value_template: >
       {%- set domains = ['automation'] -%}
       {%- for domain in domains -%}
         {%- for item in states[domain] -%}
           {% if loop.first %}
             {{loop.length}}
           {% endif %}
         {%- endfor -%}
       {%- endfor -%}
 #----- Count Device Trackers
   count_device_trackers:
     value_template: >
       {%- set domains = ['device_tracker'] -%}
           {% if loop.first %}
             {{loop.length}}
           {% endif %}
         {%- endfor -%}
       {%- endfor -%}
 #----- Count Lights
   count_lights:
     value_template: >
       {%- set domains = ['light'] -%}
           {% if loop.first %}
             {{loop.length}}
           {% endif %}
         {%- endfor -%}
       {%- endfor -%}
 #----- Count Binary Sensors
   count_binary_sensors:
     value_template: >
       {%- set domains = ['binary_sensor'] -%}
           {% if loop.first %}
             {{loop.length}}
           {% endif %}
         {%- endfor -%}
       {%- endfor -%}
 #----- Count Sensors
   count_sensors:
     value_template: >
       {%- set domains = ['sensor'] -%}
           {% if loop.first %}
             {{loop.length}}
           {% endif %}
         {%- endfor -%}
       {%- endfor -%}
 #----- Count Switches
   count_switches:
     value_template: >
       {%- set domains = ['switch'] -%}
           {% if loop.first %}
             {{loop.length}}
           {% endif %}
         {%- endfor -%}
       {%- endfor -%}
 #----- Count Zones
   count_zones:
     value_template: >
       {%- set domains = ['zone'] -%}
           {% if loop.first %}
             {{loop.length}}
           {% endif %}
         {%- endfor -%}
       {%- endfor -%}
 #----- Count Cameras
   count_cameras:
     value_template: >
       {%- set domains = ['camera'] -%}
           {% if loop.first %}
             {{loop.length}}
           {% endif %}
         {%- endfor -%}
       {%- endfor -%}
 #----- Count Plants
   count_plants:
     value_template: >
       {%- set domains = ['plant'] -%}
           {% if loop.first %}
             {{loop.length}}
           {% endif %}
         {%- endfor -%}
       {%- endfor -%}
 #----- Count Media Players
   count_media_players:
     value_template: >
       {%- set domains = ['media_player'] -%}
           {% if loop.first %}
             {{loop.length}}
           {% endif %}
         {%- endfor -%}
       {%- endfor -%}
 #----- Count Scripts
   count_scripts:
     value_template: >
       {%- set domains = ['script'] -%}
           {% if loop.first %}
             {{loop.length}}
           {% endif %}
         {%- endfor -%}
       {%- endfor -%}
 #----- Count Locks
   count_lock:
     value_template: >
       {%- set domains = ['lock'] -%}
           {% if loop.first %}
             {{loop.length}}
           {% endif %}
         {%- endfor -%}
       {%- endfor -%}
 #----- Count Vacuum
   count_vacuum:
     value_template: >
       {%- set domains = ['vacuum'] -%}
           {% if loop.first %}
             {{loop.length}}
           {% endif %}
         {%- endfor -%}
       {%- endfor -%}
 #----- Count Zwave
   count_zwave:
     value_template: >
       {%- set domains = ['zwave'] -%}
           {% if loop.first %}
             {{loop.length}}
           {% endif %}
         {%- endfor -%}
       {%- endfor -%}
Excellent! Thanks!!
