Sensor counts energy specific time
Hey friends,
Can you please help me how to customize a daily utility meter that is only counting between a specific time (for example from 3pm to 4pm)? So I will get easily a quick overview of the last days.
The easiest way to do this is with tariffs. Each tariff creates it’s own sensor and you switch between which tariff is accumulating using an automation.
e.g.
utility_meter:
  daily_energy:
    source: sensor.energy
    cycle: daily
    tariffs:
      - afternnon_3_to_4pm
      - other_times
automation:
    - platform: time
      at: "15:00:00"
      variables:
        tariff: "afternnon_3_to_4pm"
    - platform: time
      at: "16:00:00"
      variables:
        tariff: "other_times"
    - service: select.select_option
        entity_id: select.daily_energy
        option: "{{ tariff }}"
You can see the afternoon daily totals in sensor.daily_energy_afternnon_3_to_4pm
You can ignore sensor.daily_energy_other_times
See the utility meter advanced configuration section here: https://www.home-assistant.io/integrations/utility_meter/#advanced-configuration
