Hi
I have several temp sensors, a motion sensor and a combiner temp and humidity sensor going to a mysensors ESP8255 Wifi Gateway. I am running 0.40.0 HA, but after running for a few hours, the data from the sensors stop. Restarting HA get all working again for a few hours again. I have my error log below. Could someone give me some idea what maybe causing this.
Thanks Laurie
17-03-22 07:05:58 WARNING (Thread-4) [homeassistant.components.emulated_hue] Listen IP address not specified, auto-detected address is 192.168.1.150
17-03-22 07:05:58 WARNING (Thread-4) [homeassistant.components.emulated_hue] When targetting Google Home, listening port has to be port 80
17-03-22 07:06:07 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
17-03-22 07:06:07 WARNING (MainThread) [homeassistant.setup] Setup of switch is taking over 10 seconds.
17-03-22 07:06:07 WARNING (MainThread) [homeassistant.setup] Setup of climate is taking over 10 seconds.
17-03-22 07:06:07 WARNING (MainThread) [homeassistant.setup] Setup of light is taking over 10 seconds.
17-03-22 07:06:08 WARNING (MainThread) [homeassistant.setup] Setup of device_tracker is taking over 10 seconds.
17-03-22 07:06:17 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=147 from 2017-03-20 14:10:37.131583)
17-03-22 07:06:18 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
17-03-22 07:07:13 ERROR (Thread-12) [homeassistant.components.recorder.util] Error executing query: (sqlite3.OperationalError) database is locked [SQL: ‘SELECT states.state_id AS states_state_id, states.domain AS states_domain, states.entity_id AS states_entity_id, states.state AS states_state, states.attributes AS states_attributes, states.event_id AS states_event_id, states.last_changed AS states_last_changed, states.last_updated AS states_last_updated, states.created AS states_created \nFROM states \nWHERE (states.domain IN (?, ?) OR states.last_changed = states.last_updated) AND states.last_updated > ? AND states.entity_id IN (?) AND states.last_updated < ? ORDER BY states.entity_id, states.last_updated’] [parameters: (‘thermostat’, ‘climate’, ‘2017-03-21 07:07:07.999011’, ‘sensor.temperature_sensor_67_5’, ‘2017-03-22 07:07:07.999011’)]
17-03-22 07:07:13 ERROR (MainThread) [aiohttp.server] Error handling request
File “/home/homeassistant/.homeassistant/deps/sqlalchemy/engine/base.py”, line 1182, in _execute_context
context)
File “/home/homeassistant/.homeassistant/deps/sqlalchemy/engine/default.py”, line 470, in do_execute
cursor.execute(statement, parameters)
sqlite3.OperationalError: database is locked
File “/home/homeassistant/.homeassistant/deps/aiohttp/web_server.py”, line 62, in handle_request
resp = yield from self._handler(request)
File “/home/homeassistant/.homeassistant/deps/aiohttp/web.py”, line 270, in _handle
resp = yield from handler(request)
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/ban.py”, line 58, in ban_middleware_handler
return (yield from handler(request))
File “/usr/lib/python3.4/asyncio/coroutines.py”, line 143, in coro
res = yield from res
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/init.py”, line 417, in handle
result = yield from result
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/history.py”, line 238, in get
end_time, entity_id, self.filters)
File “/usr/lib/python3.4/asyncio/futures.py”, line 388, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.4/asyncio/tasks.py”, line 286, in _wakeup
value = future.result()
File “/usr/lib/python3.4/asyncio/futures.py”, line 277, in result
raise self._exception
File “/usr/lib/python3.4/concurrent/futures/thread.py”, line 54, in run
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/history.py”, line 78, in get_significant_states
query.order_by(States.entity_id, States.last_updated))
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/recorder/util.py”, line 63, in execute
(row.to_native() for row in qry)
File “/home/homeassistant/.homeassistant/deps/sqlalchemy/orm/query.py”, line 2790, in iter
return self._execute_and_instances(context)
File “/home/homeassistant/.homeassistant/deps/sqlalchemy/orm/query.py”, line 2813, in _execute_and_instances
result = conn.execute(querycontext.statement, self._params)
File “/home/homeassistant/.homeassistant/deps/sqlalchemy/engine/base.py”, line 945, in execute
return meth(self, multiparams, params)
File “/home/homeassistant/.homeassistant/deps/sqlalchemy/sql/elements.py”, line 263, in _execute_on_connection
return connection._execute_clauseelement(self, multiparams, params)
File “/home/homeassistant/.homeassistant/deps/sqlalchemy/engine/base.py”, line 1053, in _execute_clauseelement
compiled_sql, distilled_params
File “/home/homeassistant/.homeassistant/deps/sqlalchemy/engine/base.py”, line 1189, in _execute_context
context)
File “/home/homeassistant/.homeassistant/deps/sqlalchemy/engine/base.py”, line 1393, in _handle_dbapi_exception
exc_info
File “/home/homeassistant/.homeassistant/deps/sqlalchemy/util/compat.py”, line 203, in raise_from_cause
reraise(type(exception), exception, tb=exc_tb, cause=cause)
File “/home/homeassistant/.homeassistant/deps/sqlalchemy/util/compat.py”, line 186, in reraise
raise value.with_traceback(tb)
context)
sqlalchemy.exc.OperationalError: (sqlite3.OperationalError) database is locked [SQL: ‘SELECT states.state_id AS states_state_id, states.domain AS states_domain, states.entity_id AS states_entity_id, states.state AS states_state, states.attributes AS states_attributes, states.event_id AS states_event_id, states.last_changed AS states_last_changed, states.last_updated AS states_last_updated, states.created AS states_created \nFROM states \nWHERE (states.domain IN (?, ?) OR states.last_changed = states.last_updated) AND states.last_updated > ? AND states.entity_id IN (?) AND states.last_updated < ? ORDER BY states.entity_id, states.last_updated’] [parameters: (‘thermostat’, ‘climate’, ‘2017-03-21 07:07:07.999011’, ‘sensor.temperature_sensor_67_5’, ‘2017-03-22 07:07:07.999011’)]
17-03-22 07:07:19 WARNING (Thread-5) [netdisco.ssdp] Error fetching description at http://192.168.1.150:8300/description.xml
17-03-22 07:07:24 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
