Sensor - Device Class
Hi All,
i have an issue with a sensor configured, when the state changed from off to on, the color of the entity is not changing to yellow, it’s remain the same.
This is the code under sensor: in configuration.yaml
    sensors:
      sensor_40:
        friendly_name: 'Hp Printer'
        value_template: "{% if is_state('device_tracker.c4_65_16_69_73_c0', 'home') %}on{% else %}off{% endif %}"
i also configured under customize: the class of the device to power:
    sensor.sensor_40:
      device_class: power
screenshot of the entity:
Any idea why it’s not working?
Only binary_sensor entities change color :wink:
Thank you! Can you share where it’s written?
In your binary_sensor config instead of your sensor config
@Tinkerer tried still not working would you mind help with code?
@yoni3210
other question how did you create the sensor printed pages?
Tried… what?
binary_sensor:
    sensors:
      sensor_40:
        friendly_name: 'HP Printer'
        value_template: "{{ if is_state('device_tracker.c4_65_16_69_73_c0', 'home') }}"
But see the docs - you can’t have multiple binary_sensor: lines.
follow this thread, there is a script pulling the data
