Sensor Device Type wrong for Ring Alarm Retrofit Zone device types
Very new Home Assistant user here… running in docker container.
Separately, I have Mosquitto running, tsightler’s ring-mqtt and I have the MQTT integration working in Home Assistant. So my Ring devices show up in Home Assistant.
I have wireless motion and contact sensors. Those work fine. I also have the Ring Retrofit device which is a separate mini-alarm panel designed to use existing wired alarm zones. These sensors show up not as contact sensors (with a Window icon in Home assistant) but instead as generic sensors (with a checkmark). I’m less concerned about the icon; this causes issues when I publish these to HomeKit from Home Assistant.
Does anybody know how I can map the “Retrofit Zone” device type (in MQTT it shows the MDL as “Retrofit Zone” from MQTT to its proper type (contact sensor) in Home Assistant?
