Sensor does not match unit from statistics
The unit of sensor.test (%) does not match the unit of already compiled statistics (h). Generation of long term statistics will be suppressed unless the unit changes back to h. Go to https://my.home-assistant.io/redirect/developer_statistics to fix this
I got this error because I changed the template from h to %. However the above link does not work. What am I supposed to do?
I have the same issue. Anyone can help?
Go to Developer Tools → Statistics. You should see your sensor listed with a ‘fix’ button next to it. Click that for some solutions.
