I’d like to send a delta-t temperature reading but only when the air conditioner is running. Is there a filter condition that lets you only send sensor reading based on another sensor state? Ultimately, I’d like to only send delta-t (difference between intake and discharge temperature) when the blower is running. Extra points if I can delay the first reading for 2-min to allow the temperature to stabilize.
Seems doable.
I would approach this by using a Home Assistant Sensor so that ESPHome knows if “the air conditioner is running.”
Then I’d use on_value in order to filter the publishing of temperature data. I am assuming that the ESPhome device has two temps sensors? This wasn’t mentioned.
At which point you would want to include the condition of the airconditioner in an ESPHome automation which can be written in many ways. Of which the sample is pretty solid.
on_...:
then:
- if:
condition:
lambda: 'return id(airconditioner).state == 1;'
then:
lambda: 'return id(this_sensor).state;'
or perhaps
on_...:
then:
- if:
condition:
binary_sensor.is_on: airconditioner
then:
A delayed_on
filter would do it → Binary Sensor Component — ESPHome Albeit it might make sense to have HA be configured with this.
Thanks @crlogic. It’s not quite working as expected. I’m getting an error compiling, not sure where the mistake is.
/config/acwatcher.yaml: In lambda function:
/config/acwatcher.yaml:93:34: error: return-statement with a value, in function returning 'void' [-fpermissive]
93 | lambda: 'return (id(intake_temp).state - id(discharge_temp).state);'
*** [.pioenvs/acwatcher/src/main.cpp.o] Error 1
Here is the whole thing:
esphome:
esp8266:
board: d1_mini_pro
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "key="
ota:
password: "password"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 10.1.12.239
gateway: 10.1.12.1
subnet: 255.255.255.0
ap:
ssid: "Acwatcher Fallback Hotspot"
captive_portal:
globals:
- id: hvac_on_threshold
type: float
restore_value: no
initial_value: '2.00'
dallas:
- pin: D4
# Individual sensors
- platform: dallas
address: 0x51000005d3a58b28
name: "Discharge Temperature"
filters:
- lambda: return x * (9.0/5.0) + 32.0;
unit_of_measurement: "°F"
- platform: dallas
address: 0x0e000005d3516128
name: "Intake Temperature"
# Green band
filters:
- platform: ct_clamp
sensor: adc_sensor
update_interval: 1s
filters:
- calibrate_linear:
- 0 -> 0
- 0.052 -> 4.3
- platform: adc
pin: A0
update_interval: 60s
lambda: |-
- platform: homeassistant
name: "Delta T Filtered"
entity_id: sensor.temp_delta_t_filtered
on_value:
then:
- if:
condition:
binary_sensor.is_on: hvac_stable_state
then:
binary_sensor:
lambda: |-
if (id(hvac_current).state > id(hvac_on_threshold)) {
return true;
} else {
return false;
name: "HVAC Stable State"
filters:
delayed_on:
minutes: 2
lambda: |-
return true;
} else {
return false;
Looks like line 93 is reporting the state of temp_delta_t, have you tried lambda: return id(temp_delta_t).state;
Similar issues
/config/acwatcher.yaml:93:28: error: return-statement with a value, in function returning 'void' [-fpermissive]
93 | lambda: return id(temp_delta_t).state;
========================== [FAILED] Took 5.22 seconds ==========================
Tried with and without quoting the lambda statement.
I didn’t look closely enough, sorry.
on_value:
then:
- if:
condition:
then:
Platform: Home Assistant only pulls values from HA and does not publish to HA. You want Template Sensor for that. But that also means that the template sensor doesn’t need the on_value
lambda, you want to publish to it after a temp_delta_t
update…
Was thinking more like this…
lambda: |-
on_value:
then:
- if:
condition:
then:
- sensor.template.publish:
state: !lambda 'return id(temp_delta_t).state;'
Based on your excellent guidance, I’ve got this one working.
globals:
type: float
restore_value: no
dallas:
- pin: D4
- platform: dallas
filters:
- platform: dallas
# Green band
filters:
sensor: adc_sensor
update_interval: 1s
filters:
- calibrate_linear:
- 0 -> 0
- 0.052 -> 4.3
- platform: adc
pin: A0
lambda: |-
lambda: |-
if (id(hvac_stable_state).state) {
} else {
return{};
binary_sensor:
lambda: |-
return true;
} else {
return false;
filters:
delayed_on:
minutes: 2
lambda: |-
return true;
} else {
return false;
Perfect. That works too
The next challenge I always like to investigate is; replacing the fixed x minute delay with a dynamic means to determine “if the temperature is stable”.
You can do this with HA Trend sensors
