gegy
(Georg)
January 4, 2023, 1:31pm
1
I am struggle in creating a filtered temperature sensor. The file editor shows that everything is ok, but when i check my configuration i am getting an error:
Invalid config for [sensor.filter]: [sensors] is an invalid option for [sensor.filter]. Check: sensor.filter->sensors. (See ?, line ?).
I have linked my sensor file in the configruation.yaml file using this line of code:
sensor: !include sensors.yaml
And my filtered sensor in my sensors.yaml looks like this:
- platform: filter
sensors:
filtered_realistic_out_temperature:
friendly_name: Außentemperatur (gefiltert)
entity_id: sensor.heizung_aussentemperatur
filters:
- filter: outlier
window_size: 4
radius: 60.0
unit_of_measurement: °C
device_class: temperature
Can somebody tell me what i am doing wrong?
(This is my complete sensors.yaml file)
sensors:
pool_temperature:
friendly_name: Pool Temperatur
value_template: >-
{{ states("input_number.pool_temperature_value") }}
#{{ state_attr("input_number.pool_temperature_value","unit_of_measurement") }}
icon_template: mdi:pool-thermometer
sensors:
regler_raumtemperatur:
friendly_name: Regler Raumtemperatur (mit Faktor 10)
value_template: '{{ ((states.sensor.temperatur_luftfeuchte_wohnzimmer_temperature.state | float(22) * 10.0)) | round(2) }}'
icon_template: mdi:temperature-chevron-up
- platform: filter
sensors:
filters:
- filter: outlier
window_size: 4
radius: 60.0
tom_l
January 4, 2023, 1:33pm
2
Look at the examples in the documentation compared to your incorrect configuration.
gegy
(Georg)
January 4, 2023, 1:38pm
3
So i did… now my sensors.yaml
looks like this:
sensors:
pool_temperature:
value_template: >-
sensors:
- platform: filter
filters:
- filter: outlier
window_size: 4
radius: 60.0
Nothing changed… getting the same error.
gegy
(Georg)
January 4, 2023, 1:44pm
4
Ok, i seems not to be possible to set
Thought this filtered sensor derives from sensor?
This sensors.yaml works:
sensors:
pool_temperature:
value_template: >-
sensors:
- platform: filter
filters:
- filter: outlier
window_size: 4
radius: 60.0
So how can i set now
on the filtered sensor?
Edit
It seems the filtered sensor inherits the properties from the original sensor. I will provide feedback on the documentation, missing that information. Thanks for help.
tom_l
January 4, 2023, 1:51pm
5
For the first one it only supports name
, the unit and device class are derived from the source sensor.
tom_l
January 4, 2023, 2:05pm
7
Name and friendly name behave identically. There is no need for both.
gegy
(Georg)
January 4, 2023, 2:22pm
8
Allright, so i have to use “unique_id” as id and name as “friendly_name”.
That confused me a little bit, because for sensors i am using the name (unique_id) for creating the sensor and give it a friendly name using “friendly_name”.
But now it seems to work. Thank you @tom_l
