Sensor for barcode reader - Value template raises error
I want to use a barcode scanner to quickly add items I put in the trash can to the HASS Shopping List.
So far I have the scanner connected (using this great repository: Barcode Server) that sends the barcode over mqtt to a sensor in Home assistant. This works perfectly.
mqtt:
  - name: Barcode Reader
    state_topic: "scanner/barcode"
    value_template: '{{ value_json.barcode | string }}'
Next I want to make a data lookup to put the corresponding generic product name to the shopping list. This is where I have been stuck all weekend…
My idea is to keep the value pairs in a single line JSON file and then loop through the data to populate a template sensor with the product name that can then be added to the shopping list. To test, I have created a file, barcodes.json, that looks like this:
[{"barcode":"5099765037067","product":"milk"},{"barcode":"075992561419","product":"coffee"}]
I have created this sensor:
  - platform: file
    file_path: /config/barcodes/barcodes.json
    value_template: >-
      {% set ns = namespace(found=false) %}
      {% for i in value_json %}
        {%- if i.barcode == states.sensor.barcode_reader.state %}
          {% set ns.found = true %}
          "{{ i.product }}"
        {% endif -%}
      {% endfor %}
      {% if not ns.found %} "unknown" {% endif %}
But I can’t get the sensor to work. I get the below error and the value of the sensor is “unknown” no matter what value the barcode reader sensor has.
Template variable warning: 'value_json' is undefined when rendering '{% set ns = namespace(found=false) %} {% for i in value_json %} {%- if i.barcode == states.sensor.barcode_reader.state %} {% set ns.found = true %} "{{ i.product }}" {% endif -%} {% endfor %} {% if not ns.found %} "unknown" {% endif %}'
What am I doing wrong? Or is there another way to achieve this? I first tried with the SQL integration but I learned the integration does not accept variables in SQL statements yet.
Hello Bjorn,
I know this was a long time ago, but did u have it working? And what was your config on the barcode server.
Here is my issue Barcode server issue
Hi, yes it works for me now. I changed approach and use Node red to match the barcode with a product name in first a CSV file and secondly a grocery store’s product database (ICA in Sweden). It seems you have challenges with Barcode Server which worked flawlessly for me all the time. Sorry I can’t help you further.
Great, thank you for responding! I discovered that I needed to run the server on a 64-bit operating system, which I wasn’t running at the time. Would you mind sharing your solution for searching in the CSV file?
This is what the flow looks like in Node Red. Apologies I dont know enough about Node Red to share what else you need to recreate. As you can see ther are three steps to search a CSV file. Open the file, convert it to JSON and then loop through the records to find a match.
