Sensor for number of active Home Assistant installations
With the latest software version you can see on your website https://analytics.home-assistant.io/#installations the number of active installations.
Is it possible to have a sensor that reports the number of active installations?
Can’t you just scape the page?
You can do that, but when the page changes…
Or there must be some kind of API available.
A build-in sensor would be the most easy solution.
I think this should work:
rest:
  - resource: https://analytics.home-assistant.io/data.json
    scan_interval: 3600
      - name: "Global HASS statistics"
        json_attributes_path: "$[?(@.last_updated)]"
        value_template: "OK"
        json_attributes:
          - "active_installations"
HASS currently gives me an error with any use of REST, it seems there is a bug in that integration. Even this json test example doesn’t work for me. If you have time to test, please try these and share your feedback :slight_smile:
Ok thanks, got it working:
Added this to format it the number. Use icon mdi:HomeAssistant (it seems you cannot put this in the template)
    sensors:
      active_ha_installations:
        friendly_name: Number of active HA installations
        # format as 20,070
        value_template: "{{'{0:,.0f}'.format(state_attr('sensor.global_hass_statistics','active_installations'))}}"
