Sensor for number of hours "consuming Kw"
Hello!
I was looking for a way to record the numbers of hours of a equipment working, connected to a Zingbee smart plug. But all the information I found, it is about HA History Stats, when an equipment is in position ON or in position OFF. But when I am using a smart plug to monitor my oven energy consumption (for example), the important for me is the time, “the oven is consuming more that 0 KW”. So the time it is really working.
Is possible to do this using the HA History Stats sensors, or should I use another way?
Thanks so much.
Alex.
Have a look at this post/thread Tracking Sump Pump (Idle + Run with details) - #5 by uSlackr
It’s fairly similar to what you’re looking to do so should give you a good starting point
