Air Filter Countdown
This project creates a sensor that tracks when the HVAC filter is changed, and sends an alert when it needs to be changed 90 days later.
I’m using a Wyze sense door sensor to trigger the automation when the filter cover is opened, but any door sensor can be used.
Link to project on github
This is my first post, and my first time posting a project on GitHub, so I apologize for my sloppiness! I have been using Home Assistant for about 6-8 months, but I have no coding background.
nickrout
(Nick Rout)
May 18, 2020, 9:36pm
2
Strangely I was looking for a way to record when my water filter needs changing. Your code will help. thanks
firstof9
(firstof9)
May 19, 2020, 7:56pm
3
Utilizing bits of your code I came up with this card setup instead of doing a picture entity:
Since I don’t have a reed switch on my filter door I just use a input_bool and butonized it.
Code:
cards:
- entity: input_datetime.air_filter_date_installed
type: entity
- cards:
- entity: sensor.air_filter_life_remaining
type: entity
- entity: input_boolean.filter_changed
hold_action:
action: more-info
show_icon: true
show_name: true
tap_action:
action: toggle
type: button
type: horizontal-stack
type: vertical-stack
Thanks for the great idea!
Fantastic! It looks great.
Thank you for posting this, sharing your code and writing a guide along with it. It helped me setup my info.
The only reason I am able to make anything happen in HA is because of this amazing community. Just trying to pay it forward when I can!
