I have this 119 gallon pressurized water tank in my well pump system, and I’d like to be able to monitor the pressure on the tank.
I have a very similar setup to this with a brass T pipe coming off of it, and a 3/4 inch analogue gauge. I was hoping to find a digital sensor that could replace the analogue gauge so I don’t have to run out to the well house to monitor it. Any options out there?
I’d use a pressure sensor such as this or this and connect it to an ESP running ESPhome. Have a hunt on AliExpress for one that properly suits your pressure and pipe size requirements.
@RayHollister not sure if you already ordered everything; the sensor I recommended failed very fast. Letting you know in case you have not ordered yet. I will be replacing it with the same one, so that I don’t have to rewire the box, but feel that a fair warning should be made
