Sensor from solar Modbus broke
Hey guys. I just updated to the latest release 2021.7.3. I have 2 SMA sunnyboy solar inverters that i used to use modbus and pull in the info. Everything was working correctly until i updated. I did some searching and looked at the release notes to see if there was some breaking changes. I cant seem to locate anything to explain why this happened. Could anyone help me out?
In config.yaml
sensor.yaml
#### modbus 60 sec polling ####
  - platform: modbus
    scan_interval: 60
    registers:
### SMA 6.0 INVERTER ##############
      - name: SB 6.0 Solar Power
        hub: SB 6.0 Inverter
        device_class: power
        unit_of_measurement: W
        slave: 3
        register: 30775
        register_type: input
        count: 2
    #   - name: DC Power SB Inverter CH A
    #     hub: SB 6.0 Inverter
    #     device_class: power
    #     unit_of_measurement: W
    #     slave: 3
    #     register: 30773
    #     register_type: input
    #     count: 2
    #   - name: DC Power SB Inverter CH B
    #     slave: 3
    #     register: 30961
    #     count: 2
#      - name: Grid Power SB Inverter
#        slave: 3
#        register: 30865
#        count: 2
#      - name: Grid Feed SB Inverter
#        slave: 3
#        register: 30867
#        count: 2
    #   - name: Daily Yield Inverter
    #     unit_of_measurement: 'kWh'
    #     slave: 3
    #     register: 30517
    #     count: 4
    #     scale: 0.001
    #     precision: 3
      - name: SB 6.0 Total Yield Inverter
        device_class: power
        unit_of_measurement: Wh
        slave: 3
        register: 30529
        count: 2
### SMA 6.0 INVERTER 2 ############
      - name: SB 6.0 Solar Power 2
        hub: SB 6.0 Inverter 2
        device_class: power
        slave: 3
        register: 30775
        count: 2
    #   - name: DC Power SB Inverter 2 CH A
    #     hub: SB 6.0 Inverter 2
    #     slave: 3
    #     register: 30773
    #     count: 2
    #   - name: DC Power SB Inverter 2 CH B
    #     slave: 3
    #     register: 30961
    #     count: 2
#      - name: Grid Power SB Inverter 2
#        data_type: int
#        slave: 3
#        register: 30865
#        count: 2
#      - name: Grid Feed SB Inverter 2
#        data_type: int
#        slave: 3
#        register: 30867
#        count: 2
    #   - name: Daily Yield Inverter 2
    #     slave: 3
    #     register: 30517
    #     count: 4
    #     scale: 0.001
    #     precision: 3
      - name: SB 6.0 Total Yield Inverter 2
        device_class: power
        slave: 3
        register: 30529
        count: 2
#### modbus 5 min polling ####
  - platform: modbus
    scan_interval: 300
    registers:
      - name: SB 6.0 Internal Temp Inverter
        device_class: temperature
        unit_of_measurement: C
        scale: 0.1
        precision: 1
        slave: 3
        register: 34113
        count: 2
      - name: SB 6.0 Internal Temp Inverter 2
        scale: 0.1
        precision: 1
        slave: 3
        register: 34113
        count: 2
    sensors:
      solar_power_total_watts:
        friendly_name: Solar Power Total Watts
        value_template: "{{ states('sensor.inverter_solar_acpower') | float + states('sensor.inverter_2_solar_acpower') | float }}"
        unit_of_measurement: 'watts'
      inverter_solar_acpower:
        friendly_name: Solar ACPower
        value_template: "{% if ((states('sensor.sb_6_0_solar_power') | float) < 0) %}0{% else %}{{states('sensor.sb_6_0_solar_power')}}{% endif %}"
        icon_template: "mdi:solar-power"
      inverter_2_solar_acpower:
        friendly_name: Solar ACPower 2
        value_template: "{% if ((states('sensor.sb_6_0_solar_power_2') | float) < 0) %}0{% else %}{{states('sensor.sb_6_0_solar_power_2')}}{% endif %}"
      inverter_internal_temp:
        friendly_name: Internal Temp
        value_template: "{% if ((states('sensor.sb_6_0_internal_temp_inverter') | float) < 0) %}Offline{% else %}{{states('sensor.sb_6_0_internal_temp_inverter')}}{% endif %}"
        icon_template: "mdi:thermometer"
      inverter_2_internal_temp:
        friendly_name: Internal Temp 2
        value_template: "{% if ((states('sensor.sb_6_0_internal_temp_inverter_2') | float) < 0) %}Offline{% else %}{{states('sensor.sb_6_0_internal_temp_inverter_2')}}{% endif %}"
      grid_power:
        friendly_name: Grid Power
        value_template: "{{ states('sensor.house_total_watts') | float - states('sensor.solar_power_total_watts') | float }}"
You can try changing the configuration for modbus as shown here.
The plan for modbus configuration changes was announced on 2021.4 - and listed as breaking changes on 2021.7.
i feel pretty stupid for missing that. i skipped right over it. I converted everything and seems to be back up and running. Well see in the morning when the power starts flowing back in. Thank you for the help!!
