Ok searching through the board i’ve found a simple solution.like below to be notified if a sensor hasn’t updated for XXX minutes/hours/days.
But keeping a long long list of all the sensors is quite cubersome. Maybe there is a simplier solution currently? Groups is not an option as i understand
- id: notify_sensor_offline
alias: Notify Sensor Offline
description: "Сенсор не обновлялся более"
- platform: state
entity_id: sensor.living_room_temperature_1
for: '00:10:00'
- platform: state
entity_id: sensor.outside_temperature
for: '00:10:00'
- platform: state
entity_id: sensor.bedroom_temperature
for: '00:10:00'
- platform: state
entity_id: sensor.kitchen_temperature
for: '00:10:00'
- service: notify.telegram
data_template:
message: "{{ trigger.from_state.attributes.friendly_name }} has not updated since 10 min"
Paste that into the template editor to see what it gives for you.
What you then do with that is a bit trickier, as it likely exceeds the 255-character limit of a sensor state. Also, you’d need to evaluate it on a regular basis which would be inefficient.
You could maybe have a sensor that stores the entity_id of the sensor with the most recent update time over ten minutes:
template:
- sensor:
- name: Sensor most recently over 10 mins
state: "{{ states.sensor|selectattr('last_updated','<',now()-timedelta(seconds=600))|sort(attribute='last_updated')|map(attribute='entity_id')|reverse|first }}"
…which will change whenever a sensor exceeds the 10 minutes threshold. Then trigger off that sensor changing and send a notification.
- platform: state
entity_id: sensor.sensor_most_recently_over_10_mins
data_template:
message: "{{ states[states('sensor.sensor_most_recently_over_10_mins')].attributes.friendly_name }} has not updated for 10 min"
