Sensor.hub_mode does not update when integrated using Hubitat Integration via Maker API
I am using Hubitat Integration on Home Assistant to integrate with my habitat hub. I see a ‘sensor.hub_mode’ entity created. The hub mode does correctly come through each time the integration is reloaded (e.g., when homeassitant core is reloaded). However, the same ‘sensor.hub_mode’ entity is not kept up to date in real time. Any thoughts on what might be the issue?
Thank you!
Misbah
