Sensor: If "not available" occurs keep the previous value
Hello Folks.
I use an sensor entity coming from external website and sometimes I got back the “Not available” value. There is no way to solve this issue with the support of this external service.
So what I’m looking for it’s a way to configure the entity in this way: If “not available” occurs keep the previous value. Any idea? Maybe a template sensor?
Thanks a lot
Yes, this can be done. Post your existing code, formatted properly (</> button).
Thank you @Troon
At moment I don’t have a code because I’m getting the sensor from an integration “OpenUV”: sensor.current_uv_index
But maybe the code to template it could start with:
# Filtered OpenUV sensor
    sensors:
      sensor.current_uv_index_filtered:
        friendly_name: "Open UV sensor filtered"
        value_template: >-
          {% if is_state('sensor.current_uv_index', 'unknown') %} ???????????????
Basically turning your topic subject into code:
    sensors:
        value_template: >-
            {{ states('sensor.current_uv_index_filtered') }}
          {% else %}
            {{ states('sensor.current_uv_index') }}
          {% endif %}
This will retain the prior value for a potentially-unlimited amount of time if your source sensor goes down, so it might be worth setting up an automation to alert you if it’s unknown for too long.
Thank you!
