In my config.yaml I have the following sensor for AQI calculation:
sensors:
aqistation_aqi:
friendly_name: "AQI Sensor"
value_template: >
{% set pm2_5_str = states('sensor.aqistation_pms3003_pm2_5') %}
{% set pm2_5 = pm2_5_str.split(' ')[0] | float(0) %}
{% set pm10_str = states('sensor.aqistation_pms3003_pm10') %}
{% set pm10 = pm10_str.split(' ')[0] | float(0) %}
{% set co = states('sensor.aqistation_gasppm_co') | float(0) %}
{% set no2 = states('sensor.aqistation_gasppm_no2') | float(0) %}
{% set nh3 = states('sensor.aqistation_gasppm_nh3') | float(0) %}
# Calculation for PM2.5 AQI (based on EPA AQI formula)
{% if pm2_5 <= 12 %}
{% set aqi_pm2_5 = ((50-0)/(12-0))*(pm2_5-0) + 0 %}
{% elif pm2_5 <= 35.4 %}
{% set aqi_pm2_5 = ((100-51)/(35.4-12.1))*(pm2_5-12.1) + 51 %}
{% elif pm2_5 <= 55.4 %}
{% set aqi_pm2_5 = ((150-101)/(55.4-35.5))*(pm2_5-35.5) + 101 %}
{% elif pm2_5 <= 150.4 %}
{% set aqi_pm2_5 = ((200-151)/(150.4-55.5))*(pm2_5-55.5) + 151 %}
{% else %}
{% set aqi_pm2_5 = 300 %}
{% endif %}
# Calculation for PM10 AQI (based on EPA AQI formula)
{% if pm10 <= 54 %}
{% set aqi_pm10 = ((50-0)/(54-0))*(pm10-0) + 0 %}
{% elif pm10 <= 154 %}
{% set aqi_pm10 = ((100-51)/(154-55))*(pm10-55) + 51 %}
{% elif pm10 <= 254 %}
{% set aqi_pm10 = ((150-101)/(254-155))*(pm10-155) + 101 %}
{% elif pm10 <= 354 %}
{% set aqi_pm10 = ((200-151)/(354-255))*(pm10-255) + 151 %}
{% else %}
{% set aqi_pm10 = 300 %}
{% endif %}
# Example AQI CO calculation (not EPA-based)
{% set aqi_co = co * 50 %} # Placeholder, adjust based on actual AQI calculations for CO
# Example AQI NO2 calculation (not EPA-based)
{% set aqi_no2 = no2 * 40 %} # Placeholder, adjust based on actual AQI calculations for NO2
# Example AQI NH3 calculation (not EPA-based)
{% set aqi_nh3 = nh3 * 30 %} # Placeholder, adjust based on actual AQI calculations for NH3
# Return the maximum AQI among all pollutants
{{ [aqi_pm2_5, aqi_pm10, aqi_co, aqi_no2, aqi_nh3] | max | float }}
Works like a charm in Template test in Dev tools, but shows “Unknown” in lovelace.
I split “µg/m³” from numbers in PM10 and PM2.5 sensors, the rest comes in float. Anyway, I float it repeatedly, but it doesn’t seem to be the culprit though…
Please help to sort things out.
