- platform: copy
source_id: sensor_filter
filters:
- lambda: return x - 1000;
how do I get the result to plus
Multiplication by -1 doesn’t work
the sensor value is always below 1000 (for information)
- platform: copy
filters:
Why not 1000 - x
or perhaps -(x - 1000)
Unfortunately you have to write return x at the beginning otherwise you get an error message
- platform: copy
filters:
- lambda: return - (x - 1000);
Now I understand it
I had assumed return x must always be together
Thanks for the hint
There’s also the absolute value c++ function abs().
