Sensor.last_update
I have 4 fibaro motion sensor, which are battery powered and its status is not (correct)updated
I used zwave JS to read it status
I try Z-Wave JS: Refresh value(s) in an automation but often it is still 100%. And after some time teh automation where these sensors is in not working correctly anymore
So i want to check if the sensor is still sending updates
like :sensor.last_update
but how can i check this in an automation . and send a warning that a sensor is not updated anymore or update sensor is > 2h ?
For battery powered devices I use this package. It is based on the device wake-up interval.
# multisensor_1
# ENTITY_ID to monitor
# TIMEOUT
input_boolean:
  zwave_multisensor_1_alarm_enable:
template:
  - trigger:
      - platform: homeassistant
        event: start
      - platform: state
        entity_id: sensor.multisensor_1_node_status
        to: awake
      - name: "multisensor_1_last_updated"
        state: "{{ now() }} "
    sensors:
      zwave_multisensor_1_latency:
        unit_of_measurement: secs
        value_template: >-
          {%- if as_timestamp(states("sensor.multisensor_1_last_updated"),0) == 0 %}
          0
          {%- else %}
          {{ ((as_timestamp(now(), 0) | int(0)) - as_timestamp(states('sensor.multisensor_1_last_updated'),0) | int(0)) }}
          {%- endif %}
binary_sensor:
    sensors:
      zwave_multisensor_1_online:
        value_template: >-
          {{ ( TIMEOUT - (states('sensor.zwave_multisensor_1_latency') | int(0))) > 0  and
               states('sensor.multisensor_1_node_status') != 'dead' and
               states('sensor.multisensor_1_node_status') != 'unavailable' and
               states('sensor.multisensor_1_node_status') != 'unknown'
      zwave_multisensor_1_alert:
        value_template: '{{ is_state("binary_sensor.zwave_multisensor_1_online", "on") and is_state("input_boolean.zwave_multisensor_1_alarm_enable", "on") }}'
alert:
  zwave_multisensor_1:
    name: zwave multisensor_1 alert
    message: '{{ state_attr("zone.home","friendly_name") }} zwave multisensor_1 offline - Latency: {{ states("sensor.zwave_multisensor_1_latency") }} Node {{ states("sensor.zwave_multisensor_1_node_status") }}'
    done_message: '{{ state_attr("zone.home","friendly_name") }} zwave multisensor_1 online'
    entity_id: binary_sensor.zwave_multisensor_1_alert
    state: "on"
    repeat: 240
    can_acknowledge: true
    skip_first: false
    notifiers:
      - sms_notifiers_all
recorder:
  include:
    entities:
      - binary_sensor.zwave_multisensor_1_online
      - binary_sensor.zwave_multisensor_1_alert
      - sensor.multisensor_1_node_status
      - input_boolean.zwave_multisensor_1_alarm_enable
      - alert.zwave_multisensor_1
      - sensor.zwave_multisensor_1_latency
I also have this variant that is based on getting a value update. This only works for things that periodically send data (like a temperature sensor), since motion sensors only send data on motion this approach does not work.
Note you’ll need to replace ENTITY_ID, COMMAND_CLASS, PROPERTY_NAME, and TIMEOUT
# multisensor_1
# TIMEOUT
input_boolean:
template:
  - trigger:
        event: start
      - platform: zwave_js.value_updated
        entity_id:
          - ENTITY_ID
        command_class: COMMAND_CLASS
        property: PROPERTY_NAME
    sensors:
        value_template: >-
          0
          {%- else %}
          {%- endif %}
binary_sensor:
    sensors:
        value_template: >-
alert:
    state: "on"
    repeat: 240
    skip_first: false
    notifiers:
      - sms_notifiers_all
recorder:
  include:
    entities:
Hi @PeteRage
thx for your code
My motion fibaro sensors are actually every 4 in one sensors , light, temperature, motion and fibation
So every 5 min the sensor sends data for the LUX value ( so lamps can be turned on/off)
This means the motion sensors are awake. But not sending data, like battery level every 5 min. i have to check now many times it check that normally ( now have an automation refresh value)
But i wil check you code , maybe i can use it also
greetz
