Your lighting experience, your way ā take control and customize it to perfection! ![]()
Hi all,
A lot of work has gone into this update, and weāve finally added RGB to light control!
While itās not a breaking change, some adjustments are needed to ensure your automations functions as intended (see below). A big thank you to everyone who has supported me in the past! If you havenāt yet supported my work, I hope youāll consider doing so Click Here
I have more updates planned, so stay tuned.
Let us know what you think.
Enjoy
Blacky ![]()
If youāre using āColour Temperatureā in light control, please read the information below before updating the blueprint. While this is not a breaking change, maintaining clean code will ensure the smooth operation of this blueprint.
LIGHT CONTROL UPDATE
New Input Option
- Light Colour: You now have the option to select RGB, RGBW or RGBWW in your light control option.
Bugs Fixed
- Fixed bugs when using dynamic lighting and transition from normal lights to night lights and vice versa.
STEPS REQUIRED WHEN UPGRADING ![]()
If youāre using āColour Temperatureā in light control, please read the information below before updating the blueprint. If you are not using āColour Temperatureā in light control, then there is no need to read any further and you can update without doing anything.
Before Updating Steps
If youāre reading this and havenāt updated yet, follow these simple steps to ensure the smooth operation of this blueprint:
- Navigate to Settings > Automation > Filters (top right) > Blueprints and select this sensor light blueprint. You will see a list of automations that use this blueprint.
- For each automation, deselect āColour Temperatureā for both normal lights and night lights. Record which automations had āColour Temperatureā deselected and whether it was for normal lights, night lights, or both.
- Update the blueprint.
- Repeat step 1, then reselect āColour Temperatureā for normal lights and night lights in each automation where you previously deselected it.
- Once all automations are updated, youāre done!
If You Have Already Updated Steps
If you have already pushed the update button, donāt stressājust follow the steps below.
For each automation, click the three dots in the top right and select āEdit in YAMLā. Look for the following lines of code, which indicate if you selected to use āColour Temperatureā:
- Under
"include_light_control:", look for"- use_colour_temperature". - Under
"include_night_light_control:", look for"- use_colour_temperature".
- Under
If these lines are present, record where you have selected to āUse Colour Temperatureā. Delete these lines of code as shown below, then click save.
Next, select the three dots again and choose āEdit in visual editorā. Reselect āColour Temperatureā for normal lights and night lights in each automation where you previously deleted the code, then click save.
Repeat the above steps for each automation until all are updated. Youāre all done!
If you like this blueprint? Consider hitting the
button in the top post ![]()
If you like my blueprints, and would like to show your support or just say thank you? Click Here ![]()
Enjoy
Blacky ![]()
Back to FAQ: Click Here
