πŸ’‘ Sensor Light - Motion Sensor - Door Sensor - Sun Elevation - LUX Value - Scenes - Time - Light Control - Device Tracker - Night Lights
@tman98
Looks like you would just like to turn ON some lights at sunset and OFF at sunrise. To do this you will need this blueprint :high_brightness: Smart Light. Just set your Trigger - Sun Elevation to Sun Elevation Falling - ON and Sun Elevation Rising - OFF, then adjust the elevation. Then add your lights in and any light control option.
That will turn it ON and OFF at night.
Now if you would like to increase the brightens when motion is detected use night lights. Select Enable entity state option and add your motion sensor to Night Lights - Entity State. Then set the night lights and any night lights control options. Make sure you select If lights are ON, adjust the lights when crossing over in Night Light Control
Now you light will come ON and OFF at night. When motion is detected it will activate night lights and the night lights settings.
Blacky :smiley:
