See Required = *, so you need normal lights.
If you are wanting a glow and then trigger when someone walks by only with sun condition then look at
Smart Light blueprint. Set your sun trigger, then set the lights to your glow %. Then enable night lights and use Enable entity state option as the condition. Enter in your motion sensor. Add your light in again to night lights. In Night Light Control select If lights are ON, adjust the lights when crossing over and Use cross over time delay from night lights to normal lights + brightness to what you would like.
If you got any more questions on the smart light blueprint then ask in that post.
Blacky ![]()
