πŸ’‘ Sensor Light - Motion Sensor - Door Sensor - Sun Elevation - LUX Value - Scenes - Time - Light Control - Device Tracker - Night Lights
@AJKEnter
Have a look at this blueprint :high_brightness: Smart Light
  1. Then in that blueprint set your sun elevation ON and OFF at light brightness 50%.
  2. In night light settings use Enable time option and set time for between 10.00PM and 01.00AM.
  3. In night light settings also use Enable entity state option and add your outdoor motion sensor into Night Lights - Entity State
  4. Add your lights into Night Lights
  5. In Night Light Control set your brightness to 100%.
  6. In Night Light Control select If lights are ON, adjust the lights when crossing over
  7. In Night Light Control select Use cross over time delay from night lights to normal lights and set up the Cross Over - Time Delay. This is the delay once your outdoor motion sensor goes clear it gives you time so if it detects motion again to keep the light ON.
Once you done all this it will work how you would like it to.
Blacky :grinning:
