What would be interesting is the logbook of your Aqara motion sensor when this happens. It would be good to see all the actions (state changes) from the trigger ON to when it will not turn OFF the light.
@Blacky
Thank you for your prompt response, I will try to explain myself a little better.
My intention with the 60 Min was to be able to define a maximum Light ON time even with the By-pass ON and that after this time both the By-Pass and the light would turn off. ( If during this time no one is detected ).
Which indicates that you forgot that you activated the By-Pass and the light will stay on until you deactivate it. " Children are unpredictable "
This is to solve when you press and activate the By-Pass but forget to press again to turn off the light and By-Pass.
Let’s say that the light would always turn off if after this time the By-Pass has not been deactivated and there is no movement during that time (Which indicates that no one is there). You would have to turn off the Light and the By-Pass and finish the automation to be ready for the next time.
No, there is no any additional state changes. Just “detected” and “cleared” in about 90 sec. Note, it is more that timeout that was set. Could that be triggering some unexpected execution path?
So the by-pass stops the automation from working. The option you have are, ON, OFF or keep the current state when it turns ON, yes you can set an auto OFF for 60min and after that time the by-pass turns OFF and evaluated the automation. It will ether keep the light ON if motion is detected or turn the light OFF after the “By-pass - Time Delay” if no motion is detected.
Yes this is why we have auto OFF. It can also act as a timer.
You dont need to turn OFF the light to activate the automation, you can but it will not activate the automation. To activate the automation when the by-pass is ON is turn OFF the by-pass.
Q: By-pass 101 - Every thing to know about the by-pass and how to use the “Trigger Sensor By-pass” without having a physical switch?
lets look at the logs for your lights and automation. To find your automation in logbook start to type “automation” and then find the automation. Include logs before and after this event in you screen shot.
hello Blacky
i Still use two automatisation for one light: morning/day eventing/night. (without sun conditions)
sometimes, whene the time from first automatisation ends and the other automatisation starts, the light turns off and cant turn on with motion (for some time?). (in my example at 07:00 am, wife stands in the dark kitchen “angry” and has to turn on the light with pysical button)
I am not sure of what you are trying to do exactly so it this is a bit of a hit and miss… “Dimmed state managed with a schedule” so there is a automation that turns the lights ON to a set brightness and then OFF again (automation 1). Amusing this is at 7pm (ON @ 30% brightness) to 11pm (OFF).
Now we would like to turn the lights on to a higher brightness when motion is detected between 7pm to 11pm and back to 30% brightness.
We will need to create another automation for this (automation 2). Automation 2 uses time from 7:01 pm to 10:49 pm. Note if your delay time is 5 min then set the 10:49 to 10:44. Set the light to 100% brightness or what every you like then create a scene with your lights at 30% brightness and put that scene in “Scenes to turn OFF” Now you lights will go to 100% when triggered and then back to 30% when OFF.
Hi @Blacky , i want the same as @fitz247 and i tried your suggestion but it does not work completely as expected. But i do think the blueprint must be able to.
here is what i did with your blueprint implementation:
front light is on at 20%,
a motion triggers,
ceiling light and front light turn on at 100%,
after time T (5 min) the ceiling light turns off,
in the blue print i call a turn off scene: dim front light at 20%,
result: ceiling light is off and front light is also turned off. Not good! and not expected.
The strange part is: if i start with front light off, it does work. It ends with light ceiling off and front light at 20%. So it seems that is doesn’t work if the light is already on before the blueprint starts??
Is this normal behaviour or am i doing something wrong? ( i have the latest blueprint.)
I do have one other question: why is it not possible to call another automation and why does it have to be a scene?
I was wondering if it would make sense whenever a light is turned off (by inactivity of the trigger) to turn off “related lights” as well.
For example, it is night time and only night lights are on after motion. Light is not enough for the task I’m doing so I explicitly turn on the day lights. When motion is gone and the automation turns off lights, it would turn off Day and Night lights, and not only the one that was turned on by the automation.
