Awesome blueprint! I have an Aqara FP2 presence sensor in my dining room. I use the FP2 as a trigger for your blueprint. However, due to the configuration of the room (open concept), I want the motion trigger to only trigger if the FP2 reports presence for xx seconds (say 15 seconds); NOT a 15 second delay in turning the lights on. The presence sensor must continuously report presence for at least 15 seconds before the trigger is triggered.
I donāt see a way in your blueprint to modify the trigger āonā period to allow for such a trigger period. Whatās the best way to do this?
Ok great, thanks!! I will implement this when Iām back home tonight. (And Iām new to template sensors so appreciate the faq link.)
Re: item #1ā¦Iāve tried using one motion sensor in every possible position by/around the zone to trigger the light on the ceiling. But no matter where I put it, there are always accidental triggers when someone walks nearby the area but not into the actual intended area (due to the layout of the hallway/corner). If I use 2 motion sensors across from each other, I can define a specific zone where only both sensors are tripped and not just one or the other. (Kind of like the overlap in a venn diagram.) Is it possible to use the blueprint where both motion sensors need to be tripped together, as the trigger?
Actually⦠looking at your solution for item #2, I wonder if the solution for #1 is also a template sensor, but with these settings:
state: >
{% if is_state('binary_sensor.motion_sensor_1_here', 'on') and is_state('binary_sensor.motion_sensor_2_here', 'off') %}
off
{% elif is_state('binary_sensor.motion_sensor_1_here', 'on') and is_state('binary_sensor.motion_sensor_2_here', 'on') %}
on
{% elif is_state('binary_sensor.motion_sensor_1_here', 'off') and is_state('binary_sensor.motion_sensor_2_here', 'on') %}
off
{% elif is_state('binary_sensor.motion_sensor_1_here', 'off') and is_state('binary_sensor.motion_sensor_2_here', 'off') %}
off
Iām testing this great blueprintš, but I need to know if the scenario allows to restore the lighting in the room, after turning it off in absence and on again in presence.
Iām using an FP2 sensor, and I would like a feature where the light turns off in absence after a certain amount of time (or switches to some sort of scene for absence in the room).
In doing so, Home Assistant will take some sort of āfingerprintā of the lighting status (on/off, brightness level, color temperature and color of each light) before turning it off.
And when it resumes presence in the room, it will restore the lighting scene to exactly the state before it was turned off in absence.
Is this possible ? Alternatively does anyone have an idea for this ?
Thanks for your quick response and explanation. I will test this coming weekend.
Maybe it s an idea to add an option to the Nightlight to be triggerd on a motion sensor, so a dedicated trigger sensor for night lightsā¦ā¦
If you donāt use the Light Control Options then yes it just turns on what you have before⦠so if your light allows for this then yes it will do that but donāt enable any Light Control Options.
If you use the Light Control Options then no it will not restore it to the automation setting. It will only apply the settings you have set. If you change them when it is ON then they will stay that way until the light is OFF, then it will apply what is in the automation next time it turns ON.
Thanks for the reply, but unfortunately I guess I misunderstood. Or maybe I mean something elseā¦
I have home lighting based on Philips HUE (Zigbee Light Link).
The lighting is also integrated in Home Assistant. Itās mostly controlled by the custom original Hue controllers (Dimmer Switch, Dial Tap and Smart Button). It is also controlled by various scenarios and automations. And also from Google Home Assistant.
The color temperature of the lighting is also controlled in real time in H.A. using the āAdaptive Lightingā plugin.
My question - if I use your āBlue Printā in conjunction with the Aqara FP2 occupancy sensor, will this scenario be able to restore the lighting to the exact previous state when I enter the room, before it was automatically turned off for the absent state by the same scenario also by your scenario?
That is, can your scenario āfingerprintā (remember) the current settings of all lights that are on when the lights are turned off in absence?
So far I have not been able to do that, and the lighting is always just on-reset to some preset lighting scene, as specified in your blueprint configuration.
So Iām throwing this out there not because I know how to do it, but because I think it might be a feasible solution for your needs if someone can write the code.
It could get messy, but what if you had a script that was called that created a scene of the ācurrent settingsā just before enabling the motion detection scene?
If you can create the new scene in a way that overwrites the ālastā current settings scene and set that as the scene to return to, youāll accomplish what I think youāre trying to do.
Edit to add: It seems you could write a script to log data to a file. If this same concept could be applied to your use case, I would expect that you could log the status of an entity to the scripts.yaml file in place of the status that was there last.
Actually just on the new 2023.12 blueprint update feature⦠it says Iām not worthy to update to the newest version of the blueprint (5.1 at this point in time) using the new method so do I just manually update to 5.1 then in the future the HA people will say your blueprint is worthy for easy updating? I wonder if they will ever realse a notification service that a blueprint HAS an update so we know.
FAQ - How To Update Blueprint on Home Assistant Version: 2023.12.0 +
Important: Occasionally, updates may include breaking changes or additional requirements. It is highly recommended to perform a full backup of your Home Assistant before updating any blueprint. Check the blueprintās post for notifications about changes, but be aware that not all changes may be announced. A full backup ensures you can roll back if any issues arise.
HOW TO UPDATE A BLUEPRINT
EASY WAY
Go to forum of the blueprint and click the Import Blueprint blue button again.
Follow the steps.
IN HOME ASSISTANT
Go into settings / automation & scenes / click on the blueprint tab at the top and then the 3 dots next to the blueprint you would like to update.
STOP Have you done a full backup If you are happy with everything (again, a backup of HA) then and only then should you click the "re-import" button.
Once you click the "re-import blueprint" button a confirmation message will appear down the bottom.
Your done!! You blueprint is updated
NOT WORKING
Not Working For You - Looks like you manually installed the blueprint. If that is the case then you will have to manually update it. Click Here to go through the steps on how to do that. You can also see the TIPS section below.
TIPS
But Wait!! If you would like to take advantage of this new update feature then you will have to import the blueprint again. Then update all of your automations, but check out the "Tip" below as it is not that hard to do.
TIP - In the YAML file of your existing automations is a file path. Once you imported the blueprint into your HA you can just change the file path to the new location in your existing automations. If you are unsure of the file path just add a test automation with the newly imported blueprint and go into your automation, top right 3 dots, Edit in YAML, and you will see the file path. Then copy the path of the newly imported blueprint automation.
Before you update the path: First copy the YAML of the existing automation you would like to update and save it in another file as your back up, yes I like back ups.
Once you have the new file path, use this file path in the existing automations you would like to update by replacing it with the new file path and clicking save. Do one at a time and check if it worked. You will then be able to use the new update feature in the future
Hi there, it would be very useful if the Github Gist would be moved to a Repo. Then we will be able to subscribe and get notifications of new releases.
Is there a way to do the oppsite with dynamic lighting. Maybe not even use lux but the value of sun elevation. So when you are using the bathroom at 2 am you dont get flash banged. So from dusk to dawn the brightness decreases to the low value and starts to increase as dawn approaches.
āYou have the option to use the āDynamic Lightingā. It will dynamically adjust the brightness % to a floating lux value. When it gets darker your brightness will increase and as it gets lighter your brightness will decrease.ā
Thatās just for comments, not code changes - also, you wouldnāt want to get a notification for every new revision of a snippet being posted.
This is why a Github Repo would be much better - even if itās just a single file⦠you can then trigger a āreleaseā when youāre done with all new updates and itās stable enough to release
Yea I thought of this when setting it all up but HA recommended using a Gist. Hopefully HA will work on it so it will notify us all within HA when the file has changed or give us directions on what they would like us to do. They did touch on it the last YouTube release and even possibility of warning you if it will break and maybe give an option to fix it. Hope they develop something here.
The āre-import blueprintā is a nice new feature as it is now realy easy to update.
