Hey, just another thank you for the blueprint. I just loaded it yesterday and am only working with one bulb so far. Many options! Great work! Works great, once I fixed my mistake of entity vs sensor. I also just loaded your sensor light add-on. Both appear to meet and exceed my needs.
Just responding to my own post to help anyone that may be trying to do the same thing.
1-2. No need for a helper if HA recognizes your TV. Just set it as the entity in the bypass.
3. No need for a new template binary sensor.
4. Create 2nd automation with lights as required. Use the new Turn Light, Switch or Scene On or Off automation.
5. Add the TV as the entity into the 2nd automation by-pass option 3.
Okay, thanks John ⌠I will have to add this to my list so I can test it. Currently I have completed the next release and working through final checks so I am not sure if I will get to this before then but I will look into it.
Yep I know what that is. Because you are using scenes only and the way scenes are handled in HA the automation canât tell if it is ON or OFF. The good news is I have been working on this and it has been resolved. Stay turned for the next release that will be out soon. If you canât wait for it then what you can do is just add one light entity used in the scene into âLights - Switches - Scenes - Scriptsâ and âNight Lightsâ.
This option is used to add a condition that only allows the automation to run when it is dark or below the âAmbientâ settings. Itâs a global condition that can work alongside other options.
Ambient Light Sensor
Consider utilizing a primary outdoor sensor to detect the actual outdoor LUX value. This approach can be beneficial as it allows for the use of a single sensor across all your lighting automation setups. You may opt to use indoor sensors when the outdoor LUX value becomes irrelevant, such as when using lights in your garage with the door closed or when closing blinds in rooms. Itâs really up to you and what suits your site conditions best.
Ambient Light Sensor - Site Conditions
In some cases when your lights turn ON, your ambient light sensor is affected, increasing its LUX value. This can cause the lights to go OFF prematurely. Please select an option that best suits your installation.
NOTE - If using an buffer zone between the high and low lux value, then please select NO.
Ambient Light - Low & High Lux Value
Having both a Low and High Lux value setting allows you to establish a buffer zone between the two. The Low value determines when the trigger is activated and the lights turn ON, potentially increasing the Lux value in the room. Conversely, the High value prevents immediate light deactivation, serving as a buffer zone to accommodate Lux fluctuations without turning off the lights instantly.
Ambient Light - Low Lux Value
Set the Ambient Light Low Lux Value. The light will turn ON when the lux level is below the set value. This value must be equal or lower than the âHigh Lux Valueâ below. Guide is 20 lux (dusk).
Ambient Light - High Lux Value
Set the Ambient Light High Lux Value. The light will turn OFF when the lux level is above the set value. This value must be equal or higher than the âLow Lux Valueâ above. Setting a value higher than the low value allows for an offset. Guide is 80 lux (dawn).
I will look out for it. though the last one is screenshot for Utility room failed and is also a simple light and motion sensor. no Night mode, just on and off.
Just shifted all the ones with scenes to a simple light. Using the relevent colour and brightness levels.
They donât survive a restart. Just stay permanently on.
Could it be that because the lights are on a zigbee2mqtt connection that the automation starts too soon, before the lights state is recognised as being on?
Your lighting experience, your way â take control and customize it to perfection!
New Feature
Changes to Scenes & Scripts
We have added three new inputs.
Scenes & Scripts - Toggle Helper
Night Lights - Scenes & Scripts - Toggle Helper
Yes - Manage OFF script when crossing over
The purpose of adding these inputs is to ensure the proper functioning of automations when using scenes or scripts. The benefits of adding these inputs include:
You can now adjust the lights associated with your scenes and scripts after they have been activated, preventing them from resetting with each trigger.
With the addition of these inputs, you can create glow lights for night settings within a single automation, eliminating the need for multiple automations. A detailed guide on this process can be found Here.
When using scenes or scripts in conjunction with ambient options, selecting âYesâ for your site conditions will ensure that your lights remain on when the LUX value goes high.
Thereâs no longer a requirement to add just one entity in âLights - Switches - Scenes - Scriptsâ or âNight Lightâ. Simply incorporate a toggle helper into the new âScenes & Scripts - Toggle Helperâ inputs.
By including âYes - Manage OFF script when crossing overâ in the night lights lighting control options, you can ensure that a script runs smoothly when transitioning between normal lights and night lights, even when the lights are off, allowing for different OFF settings to be applied.
Home Assistant (HA) restarts will now recognize whether your scenes or scripts lights are ON and perform the correct actions. This feature can also be helpful when using lights or switches on different platforms, as HA may take longer to recognize their ON status after a restart.
Maintenance
From your feedback to create a manual we have updated a lot of input descriptions to better help understand what they do and also provided more links directly to the blueprint FAQâs. This will hopefully help you find what you are looking for when setting it up.
Code realignment.
If you like this blueprint? Consider hitting the button in the top post
If you like my blueprints, and would like to show your support or just say thank you? Click Here
Awesome @Blacky I do have a feature request for your add-on movie theater blueprint. Reedâs smart home on YouTube had a new video that does a similar thing to your blueprint, BUT he added the ability to have different lights/scenes based on the app on the Apple TV or Chomecast that is open. For example, for Spotify or Apple Music you could not dim the lights, but with Netflix, do a full movie dim. I think app specific conditions would be amazing.
If you would like to turn your your lights, switches, scenes, or scripts ON when the sun sets, then you would select a time well before the sunset and enable the sun condition. This ensures that the trigger is ON well before the sun sets but waits for the sun condition to turn your light ON. Then, the schedule will turn your lights OFF as per your schedule.
Example
This will activate your lights, switches, scenes, or scripts when the sun elevation is below -1.5 because the trigger schedule is active having an ON time 4pm. Conversely, it will deactivate them at the end of your schedule, well before the sun rises above -4.0.
I have a timing problem that I need help with.
I would like the automation to be active between 5 am am 8 am, than again from 4 pm to 9 pm. The automation is off otherwise. How can I achieve this? Time settings only allow one time range. I need it to be triggered by the motion Detector, so a schedule helper doesnât seem to be the answer.
You can use a schedule helper but your ON time will be the opposite to when you would like the automation to be active. Then you would put the schedule helper into the bypass option 2. Below is a example of the schedule. Then you wouldnât use the time option
