miky
November 23, 2018, 3:19pm
1
hello,
I try to use the sensor meteo_france, I bring in the following code in configuration.yaml
- platform: meteo_france
postal_code: '76000'
monitored_conditions:
- temperature
- weather
- wind_speed
- uv
- next_rain
- freeze_chance
- rain_chance
- snow_chance
- thunder_chance
When I check the configuration I have the following message
Failed config
General Errors:
- Platform not found: sensor.meteo_france
Do you have an idea
Merci
What version of Home Assistant are you running? I am on 0.82.1 and it is working fine for me using the following
The only reason there is no Sensor: is I use a !include for all my sensors in seperate files
postal_code: '45000'
- temperature
- weather
- wind_speed
- uv
- next_rain
- freeze_chance
- rain_chance
- snow_chance
- thunder_chance
miky
November 23, 2018, 7:26pm
3
I use the version 0.60.1 which I have upgrade and normally I have the version 0.82.1. I am going to make the test with a new version
Merci
miky
November 24, 2018, 10:02am
4
After update in 0.82.1 that works very well. Thank you
I’ve a lot of error linked to this integration since today. Am I alone ?
jblb
(Jb Lb)
June 3, 2019, 7:09pm
6
@oncleben31 you are not alone, I’ve also got error since a few days… probably something change in meteo-france site.
Hi me too… the input weather.city disappeared from entities…
Do you have the same thing ?
Root cause founded. PR merged in dev branch. Should be available in next release. Thanks to @victorcerutti
Ok, thank you for your work !!
The next release means in 2 weeks, in 0.95 ?
I think it’s a 3 weeks cycle now.
Since the version 113.0, the integration is no more working. I deleted the integration and tried to reinstall it but it’s impossible.
