Hi everyone,
I want add discovery device - sensor text, like a helper, but define with mqtt discovery.
I have a problem - I cannot set new value for text mqtt sensor. No matter what i do, I saw only “unknown” at value of text sensor
code function block “config”
msg.topic = "homeassistant/text/szczecin_text/config"
msg.payload = {
"object_id": "szczecin_text",
"unique_id": "szczecin_text",
"name": "szczecin text",
"icon": "mdi:ab-testing",
"mode": "text",
"command_topic": "miasta_tekstowe/szczecin/cmd",
"state_topic": "miasta_tekstowe/szczcin/stan",
"min": 2,
"max": 20,
return msg;
code function block “send value”
msg.payload = {
data: {
"value": msg.payload
return msg;
after click “config” path - I see new sensor text - but i cannot change them value.
I send them new value inject in node red to mqtt entity text (szczecin_text) … this not change a value
When i add this to dashboard, i had that same situation - First I wrote new text in sensor
and after reload … again unknown
again unknown. Have I should add extra parametrs? How i can allow sensor mqtt entity save values …
MQTT Text - Home Assistant i tried find any information about but without success…
