Sensor not appearing
I have put this into my configuration.ymal but the sensor doesn’t appear after a full restart of home assistant and i can’t see anything coming up in the logs when i search for it.
Any ideas?
  - platform: command_line
    command: "echo 100.00"
    unit_of_measurement: "USD"
I believe that’s the old formatting. I think the following should work:
command_line:
  - sensor:
Here you can find some other examples: Command line - Home Assistant
Hope this helps!
Brilliant, that was exactly the issue.
