reox
(reox)
September 15, 2023, 11:47am
1
Since yesterday, a esphome sensor is constantly showing “not available”, however sensor data is recorded. But instead of showing a solid line, I only see dots of the measurements:
I know there was the same issue some months ago and it was fixed by an update of ha core (I think). But I cannot find that thread from back then…
I’m also not sure what happened, because there was no update (neither from ha core nor esphome) at that time when the sensor started behaving this way.
Is there anything I can do to fix this?
ha core: 2023.09.2
esphome: 2023.8.3
reox
(reox)
September 22, 2023, 4:02pm
2
No one has an idea? I have no idea what caused this - because I changed nothing.
reox:
No one has an idea?
This looks like an intermittent connection problem of the ESP device.
Is it connecting via WiFi?
If so, do you know about the ESPHome diagnostic WiFi sensors WiFi Signal Sensor and WiFi Info Text Sensor ? These might give some info to troubleshoot possible WiFi problems.
reox
(reox)
September 23, 2023, 1:18pm
4
I’m not sure if that is the case… The connection seems to be okay and the RSSI is pretty constant.
The dots are also exactly 10min apart - which is the sleep time of the sensor (it runs on battery).
The only thing is, that instead of showing the last value, the sensor would show “not available” - except for a small timeframe after an update.
But for whatever reason, it started working again two hours ago 🤷
Spiro
September 23, 2023, 10:20pm
5
If you show your esp code it might give more of a clue. By any chance are you using mqtt. I suspect you might if you are using deep sleep . Have you adjusted the birth and will messages topic so they don’t match? It won’t then Mark the device as unavailable. It’ll make the graph look better. Search the forum there are many examples of needing to mangle the topics.
reox
(reox)
September 24, 2023, 9:06am
6
I haven’t touched the configuration in months… But yes, I use deep sleep.
Here are the crucial parts of the configuration.
esphome:
esp32:
board: lolin32
wifi:
ssid: !secret wifi_ssid
fast_connect: true
status_led:
pin:
number: 5
inverted: true
mqtt:
broker: !secret mqtt_broker
username: !secret mqtt_user
password: !secret mqtt_pasword
discovery: False
discovery_retain: False
birth_message:
topic: $devicename/status
payload: online
will_message:
payload: offline
on_message:
- topic: $devicename/ota_mode
payload: 'ON'
then:
- deep_sleep.prevent: deep_sleep_1
- mqtt.publish:
topic: $devicename/ota_mode_status
payload: "active"
- topic: $devicename/sleep_mode
payload: 'ON'
then:
- mqtt.publish:
payload: "disabled"
- deep_sleep.enter: deep_sleep_1
i2c:
sda: 21
scl: 22
scan: false
frequency: 10kHz
text_sensor:
- platform: wifi_info
ip_address:
- platform: version
- platform: wifi_signal
- platform: bme280
temperature:
pressure:
humidity:
address: 0x76
- platform: adc
pin: 34
attenuation: 11db
update_interval: 2s
filters:
- multiply: 2.0387
on_value_range:
- below: 3.29
then:
- mqtt.publish:
topic: $devicename/low_voltage
payload: "true"
switch:
- platform: shutdown
- platform: restart
deep_sleep:
run_duration: 10s
sleep_duration: 10min
I noticed however, that the battery depletes now much more quickly.
Before, it would last around 1 month, before I had to charge it. Now it was empty within one week.
So maybe something is messing with the deep sleep…
Spiro
September 24, 2023, 9:17am
7
will_message:
topic: $devicename/statusdisabled
Adjust like this. As long as both aren’t same topic. The broken lines should go away .
It takes esp about 8 seconds to connect to wifi then 10 seconds of run time. If you setup an automation to go back to sleep as soon as mqtt got a sensor reading in it would cut run time in half.
Set an ip address and it’ll shave a second or two off as well.
reox
(reox)
September 27, 2023, 3:56pm
8
I see, I’ll try that! Thanks!
Was there maybe a change recently? Because the sensor worked flawlessly for now almost a year.
Read up the change logs to get an idea and pay special attention to the breaking changes. In case you didn’t updated for a year you need to read all release notes for that time frame to know
Spiro
September 27, 2023, 7:53pm
10
The broken lines on graph when device went to sleep is a longstanding problem. I’m not sure how it worked for you before. Had you set the mqtt to be retained?
I’ve been using the different birth/Will topic solution for 2 1/2 years. Perhaps your device ran continuously for > 1 year. My device ran fine until 2 months ago until the box filled up with water and took out the battery charger. New charger and some sealant will hopefully see it through a few more years.
reox
(reox)
September 28, 2023, 5:44am
11
You mean here: MQTT Client Component — ESPHome ?
No, not that I’m aware of.
kind of. The battery ran flat two times and I updated the device a few times in between.
I updated esphome regulary. I also read the changelog and especially the breaking changes. As far as In can remember there was nothing where I would say this broke the device.
So I guess I was just lucky for a year and then something else changed and broke it…
So far, it works with the different birth/will messages (but it worked also a few days before I changed it, so I still have no idea what’s going on :D)
reox
(reox)
February 29, 2024, 8:34am
12
This problem is back since the update to 2024.02.00 / 2024.02.01 yesterday evening:
I checked the changelog and cannot find anything that would explain this. I updated the config due to the bme280 change and flashed an update, but it is still broken.
Relevant config:
mqtt:
discovery: False
birth_message:
payload: online
will_message:
payload: offline
on_message:
payload: 'ON'
then:
- mqtt.publish:
payload: "active"
payload: 'ON'
then:
- mqtt.publish:
payload: "disabled"
- platform: bme280_i2c
temperature:
pressure:
humidity:
address: 0x76
Masterzz
(Igors Micko)
February 29, 2024, 9:14am
13
Would be nice to check ESPHome device logs, by using, f.e.
logger:
- level: DEBUG
reox
(reox)
February 29, 2024, 9:33am
14
sure, here you go:
[10:29:48][I][logger:359]: Log initialized
[10:29:48][C][status_led:014]: Setting up Status LED...
[10:29:48][C][ota:483]: There have been 0 suspected unsuccessful boot attempts.
[10:29:48][D][esp32.preferences:114]: Saving 1 preferences to flash...
[10:29:48][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[10:29:48][I][app:029]: Running through setup()...
[10:29:48][I][i2c.arduino:183]: Performing I2C bus recovery
[10:29:48][D][text_sensor:064]: 'outdoor_version': Sending state '2024.2.1 Feb 29 2024, 10:28:42'
[10:29:48][C][bme280.sensor:091]: Setting up BME280...
[10:29:48][C][adc:047]: Setting up ADC 'outdoor_voltage'...
[10:29:48][C][adc:093]: ADC 'outdoor_voltage' setup finished!
[10:29:48][C][wifi:038]: Setting up WiFi...
[10:29:48][C][wifi:051]: Starting WiFi...
[10:29:48][C][wifi:052]: Local MAC: 30:AE:A4:07:DA:A4
[10:29:48][I][wifi:304]: WiFi Connecting to '[redacted]'...
[10:29:48][D][sensor:094]: 'outdoor_battery': Sending state nan % with 1 decimals of accuracy
[10:29:48][D][sensor:094]: 'outdoor_voltage': Sending state 4.02439 V with 2 decimals of accuracy
[10:29:49][D][sensor:094]: 'outdoor_temperature': Sending state 22.09309 °C with 1 decimals of accuracy
[10:29:49][D][sensor:094]: 'outdoor_pressure': Sending state 1000.19525 hPa with 1 decimals of accuracy
[10:29:49][D][sensor:094]: 'outdoor_humidity': Sending state 56.56543 % with 1 decimals of accuracy
[10:29:50][D][sensor:094]: 'outdoor_battery': Sending state 91.00000 % with 1 decimals of accuracy
[10:29:50][D][sensor:094]: 'outdoor_voltage': Sending state 4.02032 V with 2 decimals of accuracy
[10:29:52][D][sensor:094]: 'outdoor_battery': Sending state 90.00000 % with 1 decimals of accuracy
[10:29:52][D][sensor:094]: 'outdoor_voltage': Sending state 4.01624 V with 2 decimals of accuracy
[10:29:53][I][wifi:591]: WiFi Connected!
[10:29:53][C][wifi:409]: Local MAC: 30:AE:A4:07:DA:A4
[10:29:53][C][wifi:414]: SSID: [redacted]
[10:29:53][C][wifi:415]: IP Address: 172.20.1.12
[10:29:53][C][wifi:417]: BSSID: [redacted]
[10:29:53][C][wifi:418]: Hostname: 'outdoor'
[10:29:53][C][wifi:420]: Signal strength: -44 dB ▂▄▆█
[10:29:53][C][wifi:424]: Channel: 1
[10:29:53][C][wifi:425]: Subnet: 255.255.0.0
[10:29:53][C][wifi:426]: Gateway: 172.20.0.1
[10:29:53][C][wifi:427]: DNS1: 0.0.0.0
[10:29:53][C][wifi:428]: DNS2: 0.0.0.0
[10:29:53][D][wifi:742]: Saved fast_connect wifi settings
[10:29:53][C][ota:096]: Over-The-Air Updates:
[10:29:53][C][ota:097]: Address: 172.20.1.12:3232
[10:29:53][C][ota:100]: Using Password.
[10:29:53][C][ota:103]: OTA version: 2.
[10:29:53][C][api:025]: Setting up Home Assistant API server...
[10:29:53][C][mqtt:037]: Setting up MQTT...
[10:29:53][I][mqtt:234]: Connecting to MQTT...
[10:29:53][I][mqtt:274]: MQTT Connected!
[10:29:53][C][deep_sleep:037]: Setting up Deep Sleep...
[10:29:53][I][deep_sleep:042]: Scheduling Deep Sleep to start in 10000 ms
[10:29:53][I][app:062]: setup() finished successfully!
[10:29:53][D][sensor:094]: 'outdoor_rssi': Sending state -43.00000 dBm with 0 decimals of accuracy
[10:29:53][D][text_sensor:064]: 'outdoor_bssid': Sending state '[redacted]'
[10:29:53][D][text_sensor:064]: 'outdoor_ip': Sending state '172.20.1.12'
[10:29:53][I][app:102]: ESPHome version 2024.2.1 compiled on Feb 29 2024, 10:28:42
[10:29:53][C][status_led:019]: Status LED:
[10:29:53][C][status_led:020]: Pin: GPIO5
[10:29:53][C][wifi:577]: WiFi:
[10:29:53][C][logger:447]: Logger:
[10:29:53][C][logger:448]: Level: DEBUG
[10:29:53][C][logger:449]: Log Baud Rate: 115200
[10:29:53][C][logger:451]: Hardware UART: UART0
[10:29:53][C][i2c.arduino:053]: I2C Bus:
[10:29:53][C][i2c.arduino:054]: SDA Pin: GPIO21
[10:29:53][C][i2c.arduino:055]: SCL Pin: GPIO22
[10:29:53][C][i2c.arduino:056]: Frequency: 10000 Hz
[10:29:53][C][i2c.arduino:059]: Recovery: bus successfully recovered
[10:29:53][C][template.sensor:022]: Template Sensor 'outdoor_battery'
[10:29:53][C][template.sensor:022]: Device Class: 'battery'
[10:29:53][C][template.sensor:022]: State Class: 'measurement'
[10:29:53][C][template.sensor:022]: Unit of Measurement: '%'
[10:29:53][C][template.sensor:022]: Accuracy Decimals: 1
[10:29:53][C][template.sensor:023]: Update Interval: 2.0s
[10:29:54][C][version.text_sensor:021]: Version Text Sensor 'outdoor_version'
[10:29:54][C][version.text_sensor:021]: Icon: 'mdi:new-box'
[10:29:54][C][bme280_i2c.sensor:025]: Address: 0x76
[10:29:54][C][bme280.sensor:182]: BME280:
[10:29:54][C][bme280.sensor:194]: IIR Filter: OFF
[10:29:54][C][bme280.sensor:195]: Update Interval: 60.0s
[10:29:54][C][bme280.sensor:197]: Temperature 'outdoor_temperature'
[10:29:54][C][bme280.sensor:197]: Device Class: 'temperature'
[10:29:54][C][bme280.sensor:197]: State Class: 'measurement'
[10:29:54][C][bme280.sensor:197]: Unit of Measurement: '°C'
[10:29:54][C][bme280.sensor:197]: Accuracy Decimals: 1
[10:29:54][C][bme280.sensor:198]: Oversampling: 16x
[10:29:54][C][bme280.sensor:199]: Pressure 'outdoor_pressure'
[10:29:54][C][bme280.sensor:199]: Device Class: 'pressure'
[10:29:54][C][bme280.sensor:199]: State Class: 'measurement'
[10:29:54][C][bme280.sensor:199]: Unit of Measurement: 'hPa'
[10:29:54][C][bme280.sensor:199]: Accuracy Decimals: 1
[10:29:54][C][bme280.sensor:200]: Oversampling: 16x
[10:29:54][C][bme280.sensor:201]: Humidity 'outdoor_humidity'
[10:29:54][C][bme280.sensor:201]: Device Class: 'humidity'
[10:29:54][C][bme280.sensor:201]: State Class: 'measurement'
[10:29:54][C][bme280.sensor:201]: Unit of Measurement: '%'
[10:29:54][C][bme280.sensor:201]: Accuracy Decimals: 1
[10:29:54][C][bme280.sensor:202]: Oversampling: 16x
[10:29:54][C][adc:097]: ADC Sensor 'outdoor_voltage'
[10:29:54][C][adc:097]: Device Class: 'voltage'
[10:29:54][C][adc:097]: State Class: 'measurement'
[10:29:54][C][adc:097]: Unit of Measurement: 'V'
[10:29:54][C][adc:097]: Accuracy Decimals: 2
[10:29:54][C][adc:107]: Pin: GPIO34
[10:29:54][C][adc:122]: Attenuation: 11db
[10:29:54][C][adc:142]: Update Interval: 2.0s
[10:29:54][C][shutdown.switch:068]: Shutdown Switch 'outdoor_shutdown'
[10:29:54][C][shutdown.switch:070]: Icon: 'mdi:power'
[10:29:54][C][shutdown.switch:091]: Restore Mode: always OFF
[10:29:54][D][sensor:094]: 'outdoor_battery': Sending state 90.00000 % with 1 decimals of accuracy
[10:29:54][D][api:102]: Accepted 172.20.0.5
[10:29:54][W][component:214]: Component api took a long time for an operation (0.05 s).
[10:29:54][W][component:215]: Components should block for at most 20-30ms.
[10:29:54][C][restart:068]: Restart Switch 'outdoor_restart'
[10:29:54][C][restart:070]: Icon: 'mdi:restart'
[10:29:54][C][restart:091]: Restore Mode: always OFF
[10:29:54][C][mdns:115]: mDNS:
[10:29:54][C][mdns:116]: Hostname: outdoor
[10:29:54][D][api.connection:1121]: Home Assistant 2024.2.5 (172.20.0.5): Connected successfully
[10:29:54][C][ota:096]: Over-The-Air Updates:
[10:29:54][C][ota:097]: Address: 172.20.1.12:3232
[10:29:54][C][ota:100]: Using Password.
[10:29:54][C][ota:103]: OTA version: 2.
[10:29:54][C][api:139]: API Server:
[10:29:54][C][api:140]: Address: 172.20.1.12:6053
[10:29:54][C][api:142]: Using noise encryption: YES
[10:29:54][C][mqtt:133]: MQTT:
[10:29:54][C][mqtt:135]: Server Address: 172.20.0.5:1883 (172.20.0.5)
[10:29:54][C][mqtt:136]: Username: [redacted]
[10:29:54][C][mqtt:137]: Client ID: [redacted]
[10:29:54][C][mqtt:142]: Topic Prefix: 'outdoor'
[10:29:54][C][mqtt:144]: Log Topic: 'outdoor/debug'
[10:29:54][D][sensor:094]: 'outdoor_voltage': Sending state 4.02032 V with 2 decimals of accuracy
[10:29:54][C][wifi_info:009]: WifiInfo IPAddress 'outdoor_ip'
[10:29:54][C][wifi_info:012]: WifiInfo BSSID 'outdoor_bssid'
[10:29:54][C][wifi_signal.sensor:009]: WiFi Signal 'outdoor_rssi'
[10:29:54][C][wifi_signal.sensor:009]: Device Class: 'signal_strength'
[10:29:54][C][wifi_signal.sensor:009]: State Class: 'measurement'
[10:29:54][C][wifi_signal.sensor:009]: Unit of Measurement: 'dBm'
[10:29:54][C][wifi_signal.sensor:009]: Accuracy Decimals: 0
[10:29:54][C][mqtt:668]: MQTT Message Trigger:
[10:29:54][C][mqtt:669]: Topic: 'outdoor/ota_mode'
[10:29:54][C][mqtt:670]: QoS: 0
[10:29:54][C][mqtt.text_sensor:023]: MQTT Text Sensor 'outdoor_ip':
[10:29:54][C][mqtt.text_sensor:024]: State Topic: 'outdoor/sensor/outdoor_ip/state'
[10:29:54][C][mqtt.text_sensor:023]: MQTT Text Sensor 'outdoor_bssid':
[10:29:54][C][mqtt.text_sensor:024]: State Topic: 'outdoor/sensor/outdoor_bssid/state'
[10:29:54][C][mqtt.text_sensor:023]: MQTT Text Sensor 'outdoor_version':
[10:29:54][C][mqtt.text_sensor:024]: State Topic: 'outdoor/sensor/outdoor_version/state'
[10:29:54][C][mqtt.sensor:028]: MQTT Sensor 'outdoor_rssi':
[10:29:54][C][mqtt.sensor:032]: State Topic: 'outdoor/sensor/outdoor_rssi/state'
[10:29:54][C][mqtt.sensor:028]: MQTT Sensor 'outdoor_temperature':
[10:29:54][C][mqtt.sensor:032]: State Topic: 'outdoor/sensor/outdoor_temperature/state'
[10:29:54][C][mqtt.sensor:028]: MQTT Sensor 'outdoor_pressure':
[10:29:54][C][mqtt.sensor:032]: State Topic: 'outdoor/sensor/outdoor_pressure/state'
[10:29:54][C][mqtt.sensor:028]: MQTT Sensor 'outdoor_humidity':
[10:29:54][C][mqtt.sensor:032]: State Topic: 'outdoor/sensor/outdoor_humidity/state'
[10:29:54][C][mqtt.sensor:028]: MQTT Sensor 'outdoor_voltage':
[10:29:54][C][mqtt.sensor:032]: State Topic: 'outdoor/sensor/outdoor_voltage/state'
[10:29:54][C][mqtt.sensor:028]: MQTT Sensor 'outdoor_battery':
[10:29:54][C][mqtt.sensor:032]: State Topic: 'outdoor/sensor/outdoor_battery/state'
[10:29:54][C][mqtt.switch:041]: MQTT Switch 'outdoor_shutdown':
[10:29:54][C][mqtt.switch:042]: State Topic: 'outdoor/switch/outdoor_shutdown/state'
[10:29:54][C][mqtt.switch:042]: Command Topic: 'outdoor/switch/outdoor_shutdown/command'
[10:29:54][C][mqtt.switch:041]: MQTT Switch 'outdoor_restart':
[10:29:54][C][mqtt.switch:042]: State Topic: 'outdoor/switch/outdoor_restart/state'
[10:29:54][C][mqtt.switch:042]: Command Topic: 'outdoor/switch/outdoor_restart/command'
[10:29:55][C][mqtt:668]: MQTT Message Trigger:
[10:29:55][C][mqtt:669]: Topic: 'outdoor/sleep_mode'
[10:29:55][C][mqtt:670]: QoS: 0
[10:29:55][C][deep_sleep:049]: Setting up Deep Sleep...
[10:29:55][C][deep_sleep:052]: Sleep Duration: 900000 ms
[10:29:55][C][deep_sleep:055]: Run Duration: 10000 ms
[10:29:56][D][sensor:094]: 'outdoor_battery': Sending state 90.00000 % with 1 decimals of accuracy
[10:29:56][D][sensor:094]: 'outdoor_voltage': Sending state 4.03663 V with 2 decimals of accuracy
[10:29:58][D][sensor:094]: 'outdoor_battery': Sending state 92.00000 % with 1 decimals of accuracy
[10:29:58][D][sensor:094]: 'outdoor_voltage': Sending state 4.03663 V with 2 decimals of accuracy
[10:30:00][D][sensor:094]: 'outdoor_battery': Sending state 92.00000 % with 1 decimals of accuracy
[10:30:00][D][sensor:094]: 'outdoor_voltage': Sending state 4.03255 V with 2 decimals of accuracy
[10:30:02][D][sensor:094]: 'outdoor_battery': Sending state 92.00000 % with 1 decimals of accuracy
[10:30:02][D][sensor:094]: 'outdoor_voltage': Sending state 4.02439 V with 2 decimals of accuracy
[10:30:03][I][deep_sleep:117]: Beginning Deep Sleep
[10:30:03][I][deep_sleep:119]: Sleeping for 900000000us
[10:30:03][D][esp32.preferences:114]: Saving 2 preferences to flash...
[10:30:03][D][esp32.preferences:143]: Saving 2 preferences to flash: 0 cached, 2 written, 0 failed
Masterzz
(Igors Micko)
February 29, 2024, 10:27am
15
IMHO stopped logging too early - see no entries (except configuration) regarding BME sensor.
Collect log for longer period to have at least 2-3 successefull readings from BME.
reox
(reox)
February 29, 2024, 10:48am
16
hmm okay, so right now I have the following settings:
deep_sleep:
run_duration: 10s
sleep_duration: 15min
could it be that since 2024.2.0 10s of wake time are not enough? Is that a result of the change of the sensor?
I’ll change it to 30s and see how that goes…
I also added a update_interval: 2s
to the BME, maybe that was something changed as well? Before that worked great but it seems to prevent multiple sensor updates now?
I see now several of
[11:53:30][D][sensor:094]: 'outdoor_battery': Sending state 96.00000 % with 1 decimals of accuracy
[11:53:30][D][sensor:094]: 'outdoor_voltage': Sending state 4.05497 V with 2 decimals of accuracy
[11:53:31][D][sensor:094]: 'outdoor_temperature': Sending state 27.64074 °C with 1 decimals of accuracy
[11:53:31][D][sensor:094]: 'outdoor_pressure': Sending state 999.16827 hPa with 1 decimals of accuracy
[11:53:31][D][sensor:094]: 'outdoor_humidity': Sending state 39.40723 % with 1 decimals of accuracy
[11:53:31][W][component:214]: Component bme280_base.sensor took a long time for an operation (0.05 s).
[11:53:31][W][component:215]: Components should block for at most 20-30ms.
but the behaviour that the sensor is not available when in deep sleep is the same.
Spiro
February 29, 2024, 11:27am
17
Perhaps you just haven’t shown it , but it would be a quicker connect if you used a fixed ip address.
reox
(reox)
February 29, 2024, 11:59am
18
It is already on static IP - but could that actually be an issue? There are values transmitted via MQTT and I can see them in HA, however the device is marked as unavailable.
Spiro
February 29, 2024, 12:35pm
19
Check that dhcp hasnt handed that address out to another device or you haven’t assigned it twice.
reox
(reox)
February 29, 2024, 12:53pm
20
it is not assigned twice. But again, how can this be a problem?
And it started to behave that way exactly after the update. I also updated HAOS and core though, but I also checked the changelogs for those and could not find anything that relates to that IMHO.
