Sensor not turning off (vision security door)
I have a vision security door sensor that is not turning off every like 50th time. It was working perfectly before with another system.
I am using zwavejs2mqtt.
I have three of these sensors in use and the other two work much better - not a single issue. Battery is at 100%. All sensors have the same firmware and are the same rev.
I am thinking about getting Fibaro door sensors (Z-Wave+) to have a more reliable setup.
There probably isn’t anything I can do, right?
You should raise an issue on github once you have some debug logs when the sensors stop tracking. You can enable debug logging through the UI.
