Sensor organization
I installed the mobile application on my iPhone and two iPads. Now I have too many sensors at the top of my Overview panel. What are my best options to organize these by device or even better move them to the bottom?
I would greatly appreciate any help you can give.
You can add them to an Area
Configuration / Devices
Click on the mobile device
Click the cog (top right)
Click the drop down for Area and then Add new area… (at the bottom)
Create an area for each device, example
iPadPro 2018
iPhone Xs
Thank you VPC. I will give that a go.
VPC,
I was able to follow your instructions and created an Area for iPadPro 2018.
However all the iPadPro 2018 sensors are still at the top of my Overview panel.
How can I “declutter” them?
Thanks,
I would take control of your ui, and get rid of the badges. For the iPads I would probably just use entity cards - or if you want to keep it to a device per row, the custom- multiple entity rows.
As for your phone, I would do the same except I would create a whole separate card for the device tracker/geocoded location.
If you like the badges, I would still remove them all and then add back only those which you want up there.
If you go to the menu in the upper right and select configure ui - everything you need will be there.
I figured I would share what my location card looks like .
Thank you lawsuitup. I will look into this method.
