my sensor.philio_psp05 buglar value when it senses motion is set to 8
but i cant get the value back to 0. can that be done ?
Did you find a sollution for your problem, I have the same problem?
Hi. I changed the for the Philio in the zwcfg file.
and put in more code under <CommandClass id= for the function i needed.
look in this https://github.com/OpenZWave/open-zwave/blob/master/config/philio/psp05.xml
Hallo Niklas,
Thank you for your answer, I couldn’t fix it so I returned it to the store. Thanks for sharing anyhow.
André
