Sensor platform homeassistant question
I have an entity in Home Assistant that I want to use in ESPHome. I tried making a sensor from it using (in sensors.yaml):
  - platform: homeassistant
    entity_id: sensor.dexcom_stevermann_glucose_value
But after restarting Home Assistant, I don’t see “sensor.steve-glucose” in dev tools → states.
Any tips would be appreciated.
The answer is in the ESPHome documentation:
https://esphome.io/components/sensor/homeassistant
Screenshot 2024-03-10 at 18-17-03 Home Assistant Sensor
And to see if the sensor made it to ESPHome, you could check the esp logs, or use its web-interface
Pardon me for hijacking your post but, speaking of HA sensors. If possible, what is the correct syntax for multiple sensor attributes?
    entity_id: climate.living_room
    attribute: current_temperature
Since the thread is marked “solved”, you should start a new thread. Your question will get more views then.
I think this is correct. (I am NOT an expert). I am pretty sure that you can only specify ONE attribute of a sensor. If you don’t specify an attribute, you get the state.
Using your example:
returns the state of the entity, and
returns the value of the attribute.
As I said, I think you can only get the state or one attribute.
For multiple attributes, you need multiple sensors:
   attribute: current_humidity
There are some old posts for this topic and there’s no need to for another one. More specifically I was curious if adding multiple attributes was a native configuration available in Esphome now or in the future.
There’s posts going back to 2021 that have solutions for combining multiple attributes in 1 sensor, I already knew it was possible but, it requires a few steps and a semi-complicated lambda/C++.
Seeking a native esphome configuration if available.
