Sensor platform: mqtt Errors after Update
I updated Home Assistant to the newest version. Now I get errors:
Invalid config for [sensor.mqtt]: invalid template (TemplateSyntaxError: expected token ‘end of print statement’, got ‘integer’) for dictionary value @ data[‘value_template’]. Got ‘{{ value_json.AM2301-04.Temperature }}’. (See ?, line ?).
How to fix it?!
here is the configuration.yaml entry:
  - platform: mqtt
    state_topic: "sensor/full/espdht22/SENSOR"
    qos: 0
    unit_of_measurement: "°C"
    value_template: '{{ value_json.AM2301-04.Temperature }}'
  - platform: mqtt
    qos: 0
    unit_of_measurement: "%"
    value_template: '{{ value_json.AM2301-04.Humidity }}'
Try
{{ value_json["AM2301-04"]["Temperature"] }}
I suspect the “-04” is parsed as an integer operation.
doesn’t work :-/
Invalid config for [sensor.mqtt]: invalid template (TemplateSyntaxError: expected name or number) for dictionary value @ data[‘value_template’]. Got ‘{{ value_json.[“AM2301-04”][“Temperature”] }}’. (See ?, line ?).
I’v got it :slight_smile:
value_template: “{{ value_json[‘AM2301-04’][‘Temperature’] }}”
thanks!
