Hello !
I would like to make a two sensor that will read the temperature and humidity from local http server. The value is enclosed between two square brackets.
If i enter address
192.168.1.43
show this page with value :
Outside temperature: [12.70] ° C
Outside humidity: [100.00] %
thanks for the advice and help
Troon
(Troon)
September 27, 2022, 6:44am
3
Can you do a View Source on the web page, and post the HTML here, correctly formatted using the </> button?
<!DOCTYPE HTML>
<html>
<center>
<H1>
Data of SHT31 - Wifi NODEMCU 1.0
<br />
192.168.1.43
<br />
<font color=black size=7>Outside temperature: [11.00] °
C
<br />
<font color=black size=7>outside humadity: [100.00] %
Here is source code of html
Troon
(Troon)
September 27, 2022, 6:50pm
6
Yuk: that’s a long way from being nice HTML. Scrape sensor might work but the code is so fundamentally broken all bets are off:
- platform: scrape
name: SHT31 Temperature
resource: http://192.168.1.43
select: "font"
index: 0
value_template: "{{ value.split('[')[1].split(']')[0] }}"
unit_of_measurement: '°C'
- platform: scrape
select: "font"
index: 1
unit_of_measurement: '%'
If it’s your code producing that HTML and it’s not needed for any other use, I’d suggest returning nice clean JSON instead: something like:
{"temperature": "12.7", "humidity": "100"}
2 months work super, now after upgrade i get messege
Configuring Scrape using YAML has been moved to integration key.
Can someone help me how convert scrape to this for me new, integration key ??
- platform: scrape
resource: http://192.168.5.42
select: "font"
index: 0
- platform: scrape
select: "font"
index: 1
aceindy
(Aceindy)
January 3, 2023, 2:01pm
10
go to devices and services under settings, select integrations and add ‘scrape’ (if not already there)
but it says that scrape will be removed in the next versions…
Troon
(Troon)
January 4, 2023, 10:21am
12
No it doesn’t. It’s the YAML configuration that is being removed. You can configure it via the UI instead. See here: Scrape - Home Assistant
As per my original suggestion, if you have any control over the code coming out of your sensor, you could reconfigure it to put out valid JSON then read that with a rest
sensor. Scraping should always be a last resort.
