my energy board and sensors are running since month but recently I found out that
Power import and
Power consumption
are showing the same values which should not be the case as the solar electricity must be considered at sensor Power import.
I found out that the sensor solargen is showing always zero even at 12:00 when the production of solar electricity is very high.
My solar panels will be checked with a Shelly em in order to get precise data. The sensor: shelly_em_channel_1_power is showing accurate figues and a nice graph
But why is solargen showing zero? At yaml I cannot find any issue:
Template sensor for values of energy Solar generation (solar_power > 0)
Your template appears to output the Shelly power figure if it’s above zero, and 0 if it is below zero. Your graph shows the Shelly at -168W, so the template should be outputting zero.
