Are there any args for changing the style of a sub_entity on a sensor widget?
After hours of trying to figure it out, I found that state_text_style works to style it!
sorry that i missed when you posted the question, then i could have saved you the trouble
I appreciate that. I should have just posted the question yesterday when I started trying to figure it out.
then i would have seen it for sure
it isnt the most obvious thing.
ill ask @aimc if he would add a comment about it to the docs.
sub_entity is added later on and uses the state part in the HTML.
but not even state_text_style is in the docs.
so credits for you that you did find it at all
I added state_text_style
to the list of style arguments for sensor
thanks. did you also add a comment that it is also used for the subentity?
I did now
your a champ
