clach04
(Clach04)
1
Using last_boot (and a few others) from https://home-assistant.io/components/sensor.systemmonitor/ get truncated in a circle and not readable.
Is there additional config needed?
- platform: systemmonitor
resources:
- type: disk_use_percent
arg: c:\
- type: disk_use
arg: c:\
- type: disk_free
arg: c:\
- type: memory_free
- type: processor_use
- type: last_boot
- type: since_last_boot
fabaff
(Fabian Affolter)
2
You can put them in a group.
clach04
(Clach04)
3
You ! That helped greatly, ended up going with:
# https://home-assistant.io/components/group/
group:
machine_info:
entities:
- sensor.disk_use_c
- sensor.disk_use_c_2
- sensor.disk_free_c
- sensor.ram_free
- sensor.cpu_use
- sensor.last_boot
- sensor.since_last_boot
Thank you.
fabaff
(Fabian Affolter)
4
The badges works fine for short, numerical values.
