Sensor temperature (mqtt topic) in fahrenheit
hi,
i did a sensor (temperature sensor) that receive my weather station temperature from mqtt topic.
see below
   - platform: mqtt
      unit_of_measurement: '°C'
      state_topic: "rtl_433/AlectoV1-Temperature/40"
      force_update: true
      value_template: "{{ value_json.temperature_F }}"
unfortunatly, even if “unit_of_measurement” is in °C, the temperature is always display in fahrenheit.
i would like to convert it to celsius
do you know how to do so ?
thanks
Regards
temperature always converts to your system units. So if you select imperial as your system units, all temperatures will be displayed in ºF.
The only way to avoid this automatic setting is to change the unit_of_measurement to something other than ºF or ºC. Also, do not set the device_class.
  unit_of_measurement: 'Celcius'
I don’t understand because my homeassistant settings are set to “Celsius” and “Kilogram”
Then your unit_of_measurement needs to be ºF so that the system knows the units are in ºF so it can convert it to ºC for you.
and add, device_class: temperature
Thx for your help
Seems not working
to be sure please see my configuration.yaml file
# Loads default set of integrations. Do not remove.
default_config:
mqtt:
  broker: 192.168.1.22
  username: umqtt
  password: pass4UMQTT
  discovery: true
influxdb:
  host: a0d7b954-influxdb
  port: 8086
  database: homeassistant
  username: homeassistant
  password: homeassistant
  max_retries: 3
  default_measurement: state
# Text to speech
tts:
  - platform: google_translate
homeassistant:
  customize:
    binary_sensor.zone1:
      device_class: door
  customize_domain:
    light:
      assumed_state: false
script: !include scripts.yaml
scene: !include scenes.yaml
logger:
  default: error
  logs:
    homeassistant.components.enocean: debug
    homeassistant.components.mqtt: debug
api:
switch:
  - platform: mqtt
    command_topic: "room/light"
    payload_on: "on"
    payload_off: "off"
  - platform: mqtt
    command_topic: "tele/sonoff10/LWT"
  - platform: mqtt
    command_topic: "home/bedroom/switch1/set"
  -  platform: rpi_gpio
     ports:
       23: Sirene
light:
  - platform: mqtt
    command_topic: "hom/dd"
  - platform: mqtt
    force_update: true
  - platform: mqtt
    state_topic: "rtl_433/LaCrosse-WS2310/226"
    force_update: true
binary_sensor:
  - platform: mqtt
    device_class: "window"
    state_topic: "fhem/en_porte1/state"
    payload_on: "open"
    payload_off: "closed"
  - platform: mqtt
    device_class: "motion"
    state_topic: "fhem/pir_chambre/state"
    payload_on: "on"
    payload_off: "off"
  - platform: mqtt
    state_topic: "fhem/pir_bureau/state"
    payload_on: "on"
    payload_off: "off"
  - platform: mqtt
    state_topic: "fhem/pir_salon/state"
    payload_on: "on"
    payload_off: "off"
  - platform: mqtt
    state_topic: "fhem/pir_entree/state"
    payload_on: "on"
    payload_off: "off"
    invert_logic: true
    ports:
      5: zone1
Capture
The mqtt message is sent in Fahrenheint
{“time”:“2022-06-29 16:03:10”,“model”:“AlectoV1-Temperature”,“id”:40,“channel”:1,“battery_ok”:1,“temperature_F”:84.38,“humidity”:20,“mic”:“CHECKSUM”}
I want it to be displayed in Celsius
Thanks again for your support
regards
You have to put the units in ºF, not ºC. Are you reading what I’m telling you to do?
Change to ‘°F’
Change to ‘°F’
Change to ‘°F’
You should not have ºC anywhere in your configuration if the device is outputing ºF.
When you tell the system that a value is ºC, then the system thinks “Hey, I don’t need to convert this because it’s already in ºC”.
You’re telling the system not to convert it.
Apologies !!!
ok it is working and i do understand now
Thx
