Consider the following:
The sensor below will have the values 0,1,2 or 3.
- platform: mqtt
state_topic: “thermostat”
name: “Thermostat Operating Mode”
value_template: “{{ value_json.tmode}”
0: off
1: heat
2: cool
3: auto
Based on the value of the sensor above, I want to create another sensor to tell me the set point of the current mode. If the thermostat is in cool mode, it will publish a message with a json key of tcool. Conversely, heat will produce theat.
I want to have one standard “thermostat set point” sensor that produces the set point regardless of whether cool or heat mode is selected. Any ideas? Does this make sense?
I was thinking something with a template sensor might work, but am unsure.
