Can’t figure out what I’m doing wrong here.
Attempting to calculate the AQI from an SDS011. I have that working and returning good data for PM2.5 and PM10.0. Trying to add a Template Sensor to calculate the AQI for each. I’m sure I don’t have the ‘lambda’ configured correctly. Just can’t figure out where. The config compiles fine without this Template. Am I close here or should I trash it and start over?
name: "SDS011 PM2.5µm 24 Hour AQI"
unit_of_measurement: 'AQI'
update_interval: 60min
state_class: measurement
icon: mdi:chemical-weapon
lambda: |-
if (id(PM2524Hour).state) > 300.0 and (id(PM2524Hour).state) < 500.0
return (((500.0 - 301.0)/(500.4 - 250.5)) * ((id(PM2524Hour).state) - 250.5) + 301.0);}
if (id(PM2524Hour).state) > 200.0 and (id(PM2524Hour).state) <= 300.0
return (((300.0 - 201.0)/(250.4 - 150.5)) * ((id(PM2524Hour).state) - 150.5) + 201.0);}
if (id(PM2524Hour).state) > 150.0 and (id(PM2524Hour).state) <= 200.0
return (((200.0 - 151.0)/(150.4 - 55.5)) * ((id(PM2524Hour).state) - 55.5) + 151.0);}
if (id(PM2524Hour).state) > 100.0 and (id(PM2524Hour).state) <= 150.0
return (((150.0 - 101.0)/(55.4 - 35.5)) * ((id(PM2524Hour).state) - 35.5) + 101.0);}
if (id(PM2524Hour).state) > 50.0 and (id(PM2524Hour).state) <= 100.0
return (((100.0 - 51.0)/(35.4 - 12.1)) * ((id(PM2524Hour).state) - 12.1) + 51.0);}
else
return (((50.0 - 0.0)/(12.0 - 0.0)) * ((id(PM2524Hour).state) - 0.0) + 0.0);}
Compile errors are as follows. Searching shows it’s a common error but nothing I’ve found has fixed it.
/config/esphome/testnodemcu.yaml: In lambda function:
/config/esphome/testnodemcu.yaml:161:30: error: expected primary-expression before '>' token
/config/esphome/testnodemcu.yaml:162:7: error: expected ';' before '{' token
/config/esphome/testnodemcu.yaml:164:30: error: expected primary-expression before '>' token
/config/esphome/testnodemcu.yaml:165:7: error: expected ';' before '{' token
/config/esphome/testnodemcu.yaml:167:30: error: expected primary-expression before '>' token
/config/esphome/testnodemcu.yaml:168:7: error: expected ';' before '{' token
/config/esphome/testnodemcu.yaml:170:30: error: expected primary-expression before '>' token
/config/esphome/testnodemcu.yaml:171:7: error: expected ';' before '{' token
/config/esphome/testnodemcu.yaml:173:30: error: expected primary-expression before '>' token
/config/esphome/testnodemcu.yaml:174:7: error: expected ';' before '{' token
/config/esphome/testnodemcu.yaml:179:3: warning: control reaches end of non-void function [-Wreturn-type]
*** [/data/testnodemcu/.pioenvs/testnodemcu/src/main.cpp.o] Error 1
