Not working for me. Whatever I do it shows “needs water” which was actually my first state because I made it to say that in template if <60 (because atm it is on 52%). But when I changed the code to normal <20 it is still the same…
sensors:
ficus_benjamina_moisture:
friendly_name: 'Moisture'
value_template: >
{% if (states.sensor.ficus_benjamina_moisture.state | int < 20) %} Needs water
{% else %} (states.sensor.ficus_benjamina_moisture.state | int) All ok
{% endif %}
ficus_benjamina_conductivity:
friendly_name: 'Conductivity'
value_template: >
{% if (states.sensor.ficus_benjamina_conductivity.state | int < 350) %} Needs poop
{% else %} (states.sensor.ficus_benjamina_conductivity.state | int) All ok
{% endif %}
And I also need help in adding one more if - I tried in all forms and not successful. For example water - I would like to say if <20 “needs water”, if >60 “too much water” and if in between then “all ok”…
