but I seen only “Giorni” without the number. If I try to send command using SSH it report it correctly…so i don’t know where is the problem in lovelace or in the sensor…
I assume you are either running Hassbian or a venv installation.
Try putting the full path to the ssl-cert-check command in the configuration. The execution environment may not have that path. Perhaps try adding the path for sudo too.
You should also see the sensor information under Developer Tools -> States
Yes i’m using Hassbian.
Sorry i’m not very good with SSH and this SO.
My admin user is “pi” when I access with SSH.
Home assistant is installed with “homeassistant” user.
I’ve installed ssl-cert-check under “pi”.
Also If I try to access SSH with user “homeassistant” I get access denied after entering password so I always installed packages using pi user.
