As per the title, I’m looking for a sensor to detect if a car is in the driveway.
I’ve been looking at distance or break beam sensor. but neither seem to have popular options.
Ideally, it would be a ZWave or wifi device?
When you say you use cameras - do you just have a camera feed in your dashboard? Or some sensor setup to notify you on change of image, etc?
I use a Bluetooth iBeacon tag in one of the always powered USB ports in my car and an EspHome Bluetooth proxy in a closet close to where I usually park…
The car is approximately 15m from the BT proxy location. Seems to pick the car up at the foot of the driveway - about 25m
I use platerecognizer to detect vehicles in my drive, I have just got some cheap battery powered ibeacons from AliExpress and they seem to work ok as well
Yes, I created a camera view in Blue Iris, and using BI AI to send an MQTT message when conditions are met. HA listens to the topics.
I assumed your requirement was to detect any vehicle, but if you’re just trying to detect your own vehicles then I believe @NathanCu suggestion would work perfectly.
Thanks for the tips everyone.
I’ve not played around with any of the image recognition capabilities - sounds like it’s time to have a go!
