Hi, I want to make a sensor template to show me if my electricity is on/off at my house. I plan to use the Loadshedding Status Integration which gives me a value if there is currently loadshedding.
The integration makes the attribute ‘Currently Loadshedding’ from the entity: ‘sensor.loadshedding_local_status’ true/false depending on if there is currently loadshedding or not.
My current configuration.yaml file:
home_electricity:
friendly_name: "Home Electricity"
value_template: >-
{% if stateattr(('sensor.loadshedding_local_status', 'Currently Loadshedding') == "false") %}
On
{% if stateattr(('sensor.loadshedding_local_status', 'Currently Loadshedding') == "true") %}
Off
{% else %}
Unavailable
{% endif %}
icon_template: >-
mdi:home-lightning-bolt
mdi:home-lightning-bolt-outline
{% else %}
mdi:alert
{% endif %}
The error Home Assistant gives me:
Invalid config for [sensor.template]: invalid template (TemplateSyntaxError: Unexpected end of template. Jinja was looking for the following tags: 'elif' or 'else' or 'endif'. The innermost block that needs to be closed is 'if'.) for dictionary value @ data['sensors']['home_electricity']['icon_template']. Got '{% if stateattr((\'sensor.loadshedding_local_status\', \'Currently Loadshedding\') == "false") %}\n mdi:home-lightning-bolt\n{% if stateattr((\'sensor.loadshedding_local_status\', \'Currently Loadshedding\') == "true") %}\n mdi:home-lightning-bolt-outline\n{% else %}\n mdi:alert\n{% endif %}' invalid template (TemplateSyntaxError: Unexpected end of template. Jinja was looking for the following tags: 'elif' or 'else' or 'endif'. The innermost block that needs to be closed is 'if'.) for dictionary value @ data['sensors']['home_electricity']['value_template']. Got '{% if stateattr((\'sensor.loadshedding_local_status\', \'Currently Loadshedding\') == "false") %}\n On\n{% if stateattr((\'sensor.loadshedding_local_status\', \'Currently Loadshedding\') == "true") %}\n Off\n{% else %}\n Unavailable\n{% endif %}'. (See ?, line ?).
